Routing curved stock for a historic door
Forum topic by willhime posted 12-06-2018 04:27 PM 277 views 0 times favorited 6 replies Add to Favorites Watch
View willhime's profile
willhime
126 posts in 1741 days
12-06-2018 04:27 PM
Topic tags/keywords: jig question resource tip trick mahogany router
I’m recreating historic doors to a town theatre. Because they’re ‘historic’ everything has to be a copy. I’m concerned about the arched part of the door glass trim. I’ve recreated the profile and everything is great for the straight sections but sending a curved piece of stock through the sam multiple bit process seems that pretty dicey. Is there a safe way or jig to ensure I finish with 10 fingers intact and stock that’s not torn out ?
-- Burn your fire for no witness
View Aj2's profile
Aj2
1879 posts in 2000 days
#1 posted 12-06-2018 05:56 PM
Yeah that’s tricky, I’m not a big fan of routers but I have to do curved pieces sometimes, so here’s my guess.
You mention what wood your going with and how you layout the grain on the curve that makes a difference with short grain.
The one on the left I would try with a template and handheld.
The one on the right also a template with bearing in a table.
Cut with the grain and you will still be able to count to ten.:)
-- Aj
View DBDesigns's profile
DBDesigns
183 posts in 199 days
#2 posted 12-06-2018 06:03 PM
Not sure about the steps of your process but I would say that it would make sense to use the router on wider stock then cut it down to its finished dimension after the profile is cut. “Wider stock=more control and distant fingers.”
Then just cut the curve with the band saw.
Another approach would be to rout straight stock and then steam bend it. More work but more toys to play with!
-- I remember when Grateful wasn't Dead
View bmerrill's profile
bmerrill
26 posts in 275 days
#3 posted 12-06-2018 06:11 PM
First thought is to cut the curve section out of stock with a band saw and touch up with the sander.
Then using a router table cut the profile with a guide bearing.
-- "Do. Or do not. There is no try". Yoda
willhime
#4 posted 12-07-2018 12:15 AM
I’m using sapale mahogany. I can’t sand the curves because they have to be too exact. The inner diameter is 15.75” and outer is 17”. Exact. I’m gonna rough cut the curves with my bandsaw then flush template them. The hard part is the profile which consists of 4 separate router bits. The straight parts are easy on the router table but I’m just anxious about having to feed them through the same setup.
View jbay's profile
jbay
2882 posts in 1101 days
#5 posted 12-07-2018 12:38 AM
Make a sled and use toggle clamps.
Make an inside curve sled for the opposite side.
117328 posts in 3779 days
#6 posted 12-07-2018 01:38 AM
J like Jbay’s approach+ ordering a shaper cutter or router bit to make all the cuts of the detail all at once done by sneaking up on it making light cuts.
