Old Powermatic model 60
Forum topic by SmallShopDad posted 12-06-2018 02:26 AM 187 views 0 times favorited 1 reply Add to Favorites Watch
View SmallShopDad's profile
SmallShopDad
5 posts in 9 days
12-06-2018 02:26 AM
Hello all
This week/weekend I am going to go look at an old model 60 8” Powermatic Joiner (The green machine) I have a newer 6” Powermatic that I bough used years ago and it has worked great! I am not familiar with this model so I have been researching and reading as much as I can. I want to make sure that I am looking for all of the “right” things when giving this machine a once-over before I buy it. I would like to hear from other people that already have this machine who can tell me what to keep my eye out for. I have restored older machines before so I am not too afraid of a project. So far the bed and fence have surface rust from the two pictures I have seen. Any help would be great thanks.
1 reply so far
View therealSteveN's profile
therealSteveN
1706 posts in 776 days
#1 posted 12-06-2018 10:13 AM
First and foremost is will it run. I’d bring along a chunk of something very hard to run on it, but not something dear to your heart.
I would also bring along a good quality level, which can also act as a straight edge, and a machinist square to check fence angle.
A good purchase would have you just replacing a belt because the motor is good. Having to shim the gibs isn’t out of the ordinary, but does the outfeed table adjust, and then come right back to where it started? Of course you need the infeed to move, unless you want to lock it at 1/16” or something, because different wood will require different depth of cut.
Seller says, “it won’t run cause I don’t have the right lectric for it” I have always just assumed the motor was dead, which doesn’t have to be a deal breaker, but don’t get lopsided in the price against a new machine after you have to drop in a lot of parts. Motors aren’t cheap. It’s possible it’s just 3 phase, but are you ready for that? Again more costs if not.
Murphys law says if you pass on this, another one will come along right away. It’s Murphys because if you buy the junker, because it’s all you found, it’s a natural that the next week, a perfect used machine will come along and the guy wants half what you paid for the junker. DAMHIKT
I’ve had, and also swapped several 60”s good jointer, any jointer is really pretty basic, a few moving pieces, and a motor attached to blades mounted on a drum, clamshell, or cylinder. Used tool blades are usually not in good shape, if they are, and the guy has a second, or third set of sharp knives for it, he loved that machine.
Not sure if you are aware of them, but a lot of energy, thoughts, tips, and info at them.
Vintage Machinery
OWWM Old Wood Working Machines
-- Think safe, be safe
