Bent bandsaw wheel?!?
Forum topic by beamrider posted 621 days ago 965 views 0 times favorited 11 replies Add to Favorites Watch
View beamrider's profile
beamrider
17 posts in 1162 days
621 days ago
I go to install a new blade on this Delta 14” bandsaw earlier today, and i notice the top wheel is scraping the housing. Well, that doesnt make any sense to me, it has not been struck in any way as to bend the housing inwards, and sure enough, when I look at the back of the housing, there are no marks or dimples on it of course. So, I figure perhaps something has gotten caught between the wheel and tire somehow, so I pull the wheel, and here’s what I find…..
Hopefully you can see it, it’s not a great picture, but there’s a dent in the wheel, as if it had been hit by a lead pipe or some such instrument! Now, I DID manage to break a 1/4 inch blade a few days ago, which is what prompted the blade change in the first place, and said breakage was accompanied by a loud BANG, as usual. The question I have is, could the blade breaking have actually bent the wheel?!? If not, what the heck WOULD have bent it? And lastly, is it possible to re-true this wheel, or am I better off getting a new wheel?
Thanks!
Dave
wanders off to scratch head
11 replies so far
View Howie's profile
Howie
2449 posts in 1094 days
#1 posted 621 days ago
Don’t think the blade breaking hurt the wheel. I’ve had several 3/4” blades break without damaging anything.They all seem to emit a loud noise when they break.
Probably a new wheel is in order here. I don’t think that one will handle a bigger blade.
Don’t have a clue how it got bent. Did you purchase the saw new?
-- Don't rollerskate in a buffalo herd
beamrider
#2 posted 621 days ago
Yea, I got it new a few years ago from Lowes, nothing but problems with it so far really, I seem to spend more time keeping it all in alignment than I do cutting anything.
View Minorhero's profile
Minorhero
103 posts in 776 days
#3 posted 621 days ago
You will likely need a new wheel if your current wheel is mishapen. When you buy a new wheel (depending on how the bearings are attached) you should seriously consider replacing the bearings. You should replace them with the appropriate size bearings and make sure they have double seals (as opposed to open, or shielded).This is usually called 2RS. So if the bearing numbers are 6202, then you should buy 6202-2RS.
Hope that helps.
View MoshupTrail's profile
MoshupTrail
268 posts in 652 days
#4 posted 621 days ago
That wheel looks like it’s been dropped. Is it possible it has been bent all along and you never noticed? That would explain your comment that you spend a lot of time keeping it in alignment. I rarely have to adjust mine.
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
View 000's profile
000
3352 posts in 788 days
#5 posted 621 days ago
”That wheel looks like it’s been dropped. Is it possible it has been bent all along and you never noticed? ”
My thoughts exactly
-- When the moderator chooses sides, his site sucks.
beamrider
#6 posted 620 days ago
You know, I didnt really think about it like that, but that WOULD explain some of the problems, wouldnt it? By the way, i flipped the wheel and mounted it backwards, so I could take that picture, the “dent” was on the inside of the wheel, so I guess it’s possible that I might never have seen it before..
View gfadvm's profile
gfadvm
6654 posts in 862 days
#7 posted 620 days ago
Take it back to Lowes. I’ll bet it has been bent since you bought it. If you have never had the wheel off before I dont see how YOU could have bent it.
View Arminius's profile
Arminius
219 posts in 1975 days
#8 posted 620 days ago
Any of the current Chinese manufactured bandsaws are not really a bandsaw so much as a bandsaw kit that might happen to work out of the box. Your wheels were certainly not balanced if you had to fight alignment problems that often, and this dent is a likely explanation – a 1/4 inch blade simply cannot withstand enough force to cause that kind of inward collapse, even if all the force was optimally directed which it simply isn’t.
I would not bother re-truing the wheel, it probably was never true to begin with and would be a hard place to start from. Just don’t expect a new wheel to be perfect either. Pick up one of the books or articles (Duginske, Bird and Fortune all have good ones) that walk through a tune-up, spend an afternoon or so, and never worry about it again.
View tomd's profile (online now)
tomd
1321 posts in 1942 days
#9 posted 620 days ago
Often bandsaw wheels when you relieve the tension will wobble quite a bit, mine when changing the blade will touch the housing. Put the new blade on then tension and see if it is hitting the houseing, I’m betting it will run fine.
-- Tom D
View MrRon's profile
MrRon
1575 posts in 1415 days
#10 posted 620 days ago
You might be able to salvage that wheel by 1st removing the band, applying an epoxy to the dent and fairing it to the circumference . Re-install the band (may be time for new bands). A replacement wheel for a Grizzly BS costs $55.
View Flyin636's profile
Flyin636
61 posts in 665 days
#11 posted 619 days ago
Just a note on “straightening wheels”..........we have a dedicated three axis,Hyd wheel straightening machine used for motorcycle and car wheels.Prices “start” at 50$ + shipping…...Use this ONLY as a gauge(not soliciting in any way!).......if you can get a replacement for anywhere near this price,thats what I’d do.Good luck,636
