Parts/Accy's for Circa 1997 Jet JWTS-10JF
Forum topic by Spinzwood posted 12-05-2018 04:54 PM 435 views 0 times favorited 5 replies Add to Favorites Watch
View Spinzwood's profile
Spinzwood
16 posts in 574 days
12-05-2018 04:54 PM
Anyone know where there are parts, aftermarket or otherwise, for this saw. Just picked up a pristine one yesterday with two cast wings and support for the wings.
I’m hoping to find a dado insert and possible a mobile base for now.
5 replies so far
View CaptainKlutz's profile
CaptainKlutz
602 posts in 1696 days
#1 posted 12-05-2018 08:22 PM
http://letmegooglethat.com/?q=jet+jwts-10+dado+insert
http://letmegooglethat.com/?q=jet+jwts-10+mobile+base
Spinzwood
#2 posted 12-05-2018 08:38 PM
Doesn’t work for me. I can find Jet dado inserts.. but, I doin’t know if they are the proper size as the saw number s not the same.
View EdDantes's profile
EdDantes
42 posts in 113 days
#3 posted 12-06-2018 06:03 AM
I have this saw, but only has the stamped steel wings. I’m jealous.
I just make my own zero clearance inserts for regular/dado blades. But if you want to buy one, the Leecraft JT-164 should fit. Can’t confirm personally, but may be worth a try if you don’t go the DIY route.
I use the Grizzly Bear Crawl mobile base. For the money, I’m not sure you could do better.
View Bill_Steele's profile
Bill_Steele
451 posts in 1934 days
#4 posted 12-06-2018 07:49 PM
I also have this same saw with stamped steel wings—so I am also jealous. I’ve had this saw for a little over 20 years and its still going strong.
I make my own inserts using 1/2” plywood.
I made my own mobile base.
If your saw does not have a link belt or a PALS kit—those are 2 worthwhile upgrades in my opinion.
Pay attention to the plug connection between the motor and the on/off switch. I’ve had problems in the past where the saw will not turn on or turns off quickly after startup and I found that this connection was vibrating loose.
Spinzwood
#5 posted 12-06-2018 09:09 PM
Thanks, Bill
Not sure what a PALS kit is. I’m familiar with link belts but must confess I’ve never used one.
