Tightbond Instant Glue for Wood to Rubber
Forum topic by gfadvm posted 09-11-2011 05:10 AM 3740 views 0 times favorited 5 replies Add to Favorites Watch
View gfadvm's profile
14940 posts in 2623 days
09-11-2011 05:10 AM
I have been making rubber pads for my tall chairs from 3/8” thick strips of rubber cut from stall mats. These protect the bottoms of the char legs and prevent them slipping on concrete. I needed a quick bond so have been using TB Instant with accelerator for the last few chairs. Will this hold up [glueing black rubber to Doug Fir end grain] ?
5 replies so far
View Woodwrecker's profile
4128 posts in 3508 days
#1 posted 09-11-2011 03:51 PM
Regular rubber cement seems to work real good for me doc.
-- Eric, central Florida / Utor praemia operibus duris
View patcollins's profile
1676 posts in 2798 days
#2 posted 09-11-2011 03:56 PM
That is just superglue and will probably eventually break. The accelerator is a solvent and can possible eat away what you spray it on. For gluing difficult items i find nothing is better than Shoo Goo, it takes a few hrs to dry but it leaves a hard rubber like bond that seems to stick to anything.
View MrRon's profile
4672 posts in 3176 days
#3 posted 09-11-2011 04:52 PM
Another one called “GOOP” works great also.
View LittlePaw's profile
1571 posts in 3011 days
#4 posted 09-12-2011 12:44 AM
I use readily available “Super Sliders” available through Lowe’s. Pre-drill a small hole on each leg bottom and gently hammer them in. I like these because they swivel enough to accommodate the non-perpendicular legs to the floor and they chair slide on felt pads so it is noiseless and they don’t slip on the floor easily . . . . cheap too.
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
#5 posted 09-12-2011 03:30 AM
I tried some contact cement on my chair feet today [Weldwood Contact Cement Gel]. I’ll let you know how it works. LittlePaw – I’m afraid those wouldn’t stand up to cement/asphalt barn floors which is where most of these chairs go.
