Table saw sled - part II
Forum topic by niki posted 1862 days ago 1457 views 4 times favorited 6 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 2246 days
1862 days ago
Good day
This post is continuation of the “Table saw sled – part I”
I added a few things but…more to come…”Don’t go anywhere” :) (as they say on CNN)
regards
niki
27262 posts in 1988 days
#1 posted 1862 days ago
Hi Niki,
You couldn’t just settle for a piece of plywood and two fences of construction grade lumber!!!! :)
This is a nice sled. No….Let me retract that statement. This is a wonderful sled. You have raised the bar on miter sleds with this piece. I like the addition of the two stops to prevent side to side movement. Putting the blade guard over the entire path that the blade travels is an innovative idea.
The only thing about it that seems a bit awkward to me is the hold down. I am assuming that you use your left hand inside the sled to put downward pressure on the 1/4” plywood to hold the work piece flat to the table. This just seems a little awkward to me trying to keep downward pressure on the sled with my left hand and moving it forward with my right.
Did you ever consider mounting a pair of toggle clamps to the left side of the fence and freeing up your left hand to push the sled?
Thanks for the post. As I said in the first installment I have one of these on my to-do list.
View niki's profile
niki
#2 posted 1862 days ago
Thank you for your kind words Scott
About the “hold-down”....I did not say the last word…yet….on the pics I actually put my palm on the sled fence and press the “hold-down” with my fingers…but that is going to change…
As I said, there are 4 or 5 posts in total and you will see many changes, modifications and variations….
The “hold-down”, is going to be “semi-automatic”...no need of toggle clamps…
So, don’t do nothing till you see the last part…and maybe you’ll have some of your ideas to add… and then, choose your design or method…
Regards
niki
View DaveH's profile
DaveH
399 posts in 1945 days
#3 posted 1861 days ago
Great post and some good design ideas. Mine is not near as safe to use.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View Ad Marketing Guy - Bill's profile
314 posts in 1965 days
#4 posted 1861 days ago
Niki
EXCELLENT illustration and tutorial
That is the “Mercedes” of cutting sleds – nice job
-- Bill - - Ad-Marketing Guy, Ramsey NJ
#5 posted 1861 days ago
Thanks Niki.
I guess I got ahead of the posts and wasn’t paying attention. My wife accuses me of that all the time. :)
OK. I won’t go out and start on it tonight and will try to be patient enough until you finish the series.
View niki's profile
niki
#6 posted 1861 days ago
Thank you so much for your kind words
Bill
I’m not sure that it will be “Mercedes” but it will be at least Wolkswagen :-)
Regards
niki
