Cutting a Brass Sheet on TS
Forum topic by Dchip posted 09-11-2011 12:23 AM 1275 views 0 times favorited 6 replies Add to Favorites Watch
View Dchip's profile
Dchip
271 posts in 3491 days
09-11-2011 12:23 AM
Topic tags/keywords: question brass tablesaw
I have a brass sheet (~1/16’’ thick) epoxied b/w a couple pieces of wood (roughly 2’’ D x 10’’ L). I was hoping to cut this into 3 or 4 squares on a TS sled. With a high-tooth carbide blade (freud cross-cut) and the piece clamped down, is this a safe couple of cuts? Will it damage (or prematurely dull) the blade? Thanks.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
View horologist's profile
horologist
104 posts in 3978 days
#1 posted 09-11-2011 02:32 AM
A much better solution is to cut it on the bandsaw with a blade designed to cut metal. Safer and you will likely get a better cut. What are you trying to make?
-- Troy in Melrose, Florida
TopamaxSurvivor
18423 posts in 3914 days
#2 posted 09-11-2011 09:20 AM
I have cut nonferrous metals on my table saw. Fine tooth blade will work the best.
View ajosephg's profile
ajosephg
1880 posts in 3799 days
#3 posted 09-11-2011 01:37 PM
Since it’s already sandwiched, I don’t see any problem and it shouldn’t dull the blade any more than wood does.
-- Joe
View knotscott's profile
knotscott
8178 posts in 3614 days
#4 posted 09-11-2011 06:09 PM
The brass won’t do your blade any favors but it’s definitely doable with a carbide blade, and should even provide a decent edge. I wouldn’t suggest using a blade with a steep top bevel angle like a Hi-ATB grind, but a triple chip grind (TCG) would be very suitable.
View 1yeldud1's profile
1yeldud1
301 posts in 3281 days
#5 posted 09-11-2011 08:05 PM
Should work – just feed the work into the blade REALLY SLOW – brass should not hurt carbide if it is sandwiched between two sheets of wood – just feed it slow
Dchip
#6 posted 09-14-2011 02:36 PM
Well there’s some mixed opinions, but I think with proper fixation and slow feeding I will give it a try. Thanks all for your input.
