| Forum topic by Mike Kemper | posted 180 days ago | 529 views | 0 times favorited | 18 replies | ![]() |
180 days ago |
180 days ago |
If you want to resaw alot of cuts more than your current LIMIT, Typically, you go from about a 6” Limit to 12” Limit… How many times have you wished you could make that wider cut? If you could do it in ONE cut, would it be worth it to you? I liked mine… but haven’t used it as much as I thought I would… Not sorry about it. -- Have Fun! Joe Lyddon - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=1389" |
180 days ago |
I got it, and I am not a bit sorry. It is nice to have the capacity to slice 8” stock. If you are never going to have to do that then it probably isn’t worth it. -- Maplewood, MN |
180 days ago |
I tend to operate with the philosophy of “it is better to have it and not need it as opposed to needing it and not having it”. I put one on my saw that I got three months ago and, while, I have yet to do any resawing it is there if I need it. You have a nice bandsaw. Adding this to it will add a little more versatility to the saw. But Rikkor is right. Its only purpose is to increase your sawing height from 6 to 12 inches and if you don’t ever plan on doing this you probably don’t need it. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
180 days ago |
IMHO it’s not worth it. My Ex-bandsaw was a 14” Jet with riser. It just doesn’t have the HP or frame stiffness for enough blade tension to resaw anything well over the 6” non-riser height. If you’re willing to work around less than straight vertical cuts on taller stuff and lose a fair amount of wood to planing afterwards, then maybe OK. -- Use the fence Luke |
180 days ago |
Thanks for the replays; since this is my first Ban Saw I’m not sure how much I would use it for resawing boards wider then 6”. What Scott says makes a lot of senses “it is better to have it and not need it as opposed to needing it and not having it”. Doug also brought up a good point about the saw having enough power to do the job. The standard Jet 14” Band Saw comes with a 1 HPM, For a few dollars more I ordered the deluxe model that comes with 1 ¼ HPM, will the extra ¼ HP makes a lot of difference when it comes to resawing a 12” wide board? |
180 days ago |
Feed it slowly, the extra 1/4 HP will help. -- Maplewood, MN |
180 days ago |
The first thing you will want to do is to get rid of the cheap blade that comes with your saw unless you plan I have risers in both my bandsaws and I don’t regret it a bit. -- Gary, East TX -- The longest journey begins with a single step. |
180 days ago |
If I were you I would get it. I have to dissagree with Doug S, I have a JWBS-14CS 1hp saw and I re-saw up to 10” wide boards on it. I have re-sawn White Oak, Hard Maple and Mahogany. You need a sharp blade and it needs to be tuned up but long as you aren’t doing 200 foot runs it works great (at least for me) I don’t know what I would do without it as I do re-sawing for most every project I do. -- Scott - Chico California http://chicowoodnut.home.comcast.net |
179 days ago |
If you plan to do much frame and panel stuff, you’ll want the riser to resaw boards for the panels. I do a lot of resawing on my Rigid BS1400. I wish I had a bigger, more powerful saw, but I’ve gotten by so far. I’ve been resawing some pretty wide red oak and that stuff is really hard! -- Hailey, ID |
179 days ago |
Mike: Yup. -- Check out my new website! http://www.theeasellife.com |
179 days ago |
It’s a must have in my opinion. Re: saw power. My first band saw was an old Delta 14” with a riser and only a 1/2hp motor. With the right blade, it could resaw anything under 12”... The more power the better, but a relatively slow feed rate can do wonders too… -- Dorje (pronounced "door-jay"), Seattle, WA |
179 days ago |
it is not just nice to have, it is required for me. I dont know why they don’t sell the saw already with one. -- making sawdust.... |
179 days ago |
Mike, sorry I didn’t see this till today. I have a Jet 14” and installed the riser….worth every penny and more. It really expands what you can do, and if you do or plan to do resawing it’s a must. Buy it, you’ll not regret it. -- Jim Hallada, Chesterfield, VA |
179 days ago |
Yup! Worth every penny! |
178 days ago |
Buy the riser kit. If you never install it, it will increase the value of the saw when you resell it, as well as few things are going down in price, and woodworking tools/accessories definitely are not among the few that are. If you want you may want to wait long enough to catch a 10% off sale if its not on sale now. You don’t think you will resell it? If you don’t continue woodworking, or go into an aspect where you never need the bandsaw, you will resell it for extra $$ for whatever your passion at that time is. As far as installing it, I would play with the saw a bit first, get familiar with it and how to adjust and fine tune it. Also fully check out the saw to make sure a return/exchange is not necessary (it happens occasionally even with the best brands). After you have fully checked it out, know what “coplaner” and “drift” means, and have found how to properly tension the blade, know that the tires are good and tight, then consider installing it. With the added knowledge, you will be able to set the riser up right the first time, and you will also be able to spot any changes made due to the installation, which may eliminate a lot of time troubleshooting any problems that develop. Also by that time, you will have a better idea of what width/tooth count blades you will need most, so will spend less on the longer blades. The caveat to this is that if you are going to go with the better quality and more expensive blades, installing it earlier than later will reduce wasting money on the shorter blades. JMHO Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
178 days ago |
OK, Now I remember one of the main reasons I was looking for a forum like LJ. I was hoping someone could give me an idea of what might be wrong with my 14” bandsaw. So, sorry if this is long but I want to make sure I include all variable: I have only had it since January but used it enough to know I should have bought one years ago, and have already gotten to the point that I needed a riser (and I thought that would take me a year). 1. Before the riser, it was working fine (as far as I could tell, being a novice with it). I would assume it was the riser, except; the blades are also by a new person who has not been as reliable. My only way of differentiating would be to take the riser off, put on one of the old blades that were not a problem and see if it goes back to running better. Putting that riser on took me all day and required I rig up a pulley system to lift it. Now that it is seated on the pegs I am not even sure I could get the riser back off without rigging a come-a-long on the rafters (which I would not trust for that kind of operation). Any suggestions as to what the problem and solution might be? Thanks -- SM |
178 days ago |
Everyone convinced me I should spend the extra $75 and get the riser block so I called woodcraft and add the riser block to my order, thanks again. SM, This will be my first band saw so what I’m about to suggest comes from a book I bought called “The New Complete Guide to The Band Saw” the problem you describe started after you add the riser block. The book says that when adding a riser block it is possible to introduce a misalignment between the top and bottom wheels that could cause this type of problem you might want to check this. If If there is a misalignment it can be corretted by adding shims to the riser block.good luck. |
177 days ago |
Mike, -- SM |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1222 |
1653 |
119 |
333 |
103 |
Woodworking Trade & Swap
233 |
Coffee Lounge
923 |
LumberJocks.com Site Feedback
268 |
