How to slice a burl
Forum topic by shipwright posted 09-09-2011 09:52 PM 3331 views 1 time favorited 13 replies Add to Favorites Watch
View shipwright's profile
shipwright
7992 posts in 2822 days
09-09-2011 09:52 PM
A friend just gave me this burl which I would love to slice into veneer but I don’t want to turn it to trash so the question of you who have exoerience with this is “On what plane should I slice it for maximum effect?”
My guess is to continue on the plane at which it has been cut already. Am I right or would I get more grain effect at an angle of some sort?
Thanks in advance.
13 replies so far
View Hoakie's profile
Hoakie
306 posts in 4060 days
#1 posted 09-09-2011 10:06 PM
I say you just float it in a pond and call it “Hippo” :)
To be honest I will be looking forward to replies as I have some that I need to cut up but am a bit afraid myself.
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
View Porchfish's profile
Porchfish
824 posts in 2557 days
#2 posted 09-09-2011 10:53 PM
This is a toughie , not knowing how thick it is. Too bad it was decapitated to start with , but that’s probably how it turned into a gifted piece. At first glance , it looks like 3 pieces to me .I would separate the hippo’s head from the body. The head and neck could then be separated into 2 smaller pieces for lathe turning. The figure you see is what you will get, ,magnified by circumstance , if you continue to slice on the plane already set. The eyes you see on the top won’t be limited to that top 1/2 ” or so, but will carry through with bisecting rays (I bet) . This would be the plane to follow if you were going to resaw this lady…Veneers ? how much will you lose to kerf etc. remember that burls can often hide vacuoles and incursions of all sorts of oddities, most of which are not good for the saw blade and screw up the continuity of veneer surface area and you can end up with a whole lot less than what you thought you would If it were mine it would be lathe turned into at least three objects…but hey , I’m old and set in my ways … the hippo is an interesting idea though, just sharpen up your carving tools, add an inspired cut or two and voila, the hippo is free ! just don’t throw him/her into the pond, she’d just go belly up & sink !
Good luck, happy deciding, and have at it ! Is it a big leaf maple burl ?
-- The pig caught under the fence is always the one doing all the squealing !
View Nomad62's profile
Nomad62
726 posts in 2982 days
#3 posted 09-09-2011 11:17 PM
I’ve slice many burls, and I would recommend slicing it down just as you are looking at it, taking slices top to bottom at whatever thickness you want. You will need to have some dry stickers to use to keep them nice and flat as they dry. Have fun, burl wood is wonderful!
shipwright
#4 posted 09-10-2011 12:57 AM
It’s already dry and yes, I think it is big leaf Maple.
It was a throw in when my friend bought some other pieces so it may well be that what it was cut from is the better piece.
I do use a “woodslicer” blade and don’t lose much to kerf, so I could get a number of veneers from it.
They could go a long way in marquetry size pieces.
View Keith Fenton's profile
Keith Fenton
328 posts in 2944 days
#5 posted 09-10-2011 01:21 AM
All I see is how many pens I could make with that beauty :)
-- Scroll saw patterns @ http://www.sheilalandrydesigns.com
View peteg's profile
peteg
4299 posts in 2847 days
#6 posted 09-10-2011 01:22 AM
If you’re not sure Paul just post to NZ & I’ll send it back hollowed out, oh ,plus the shavings, it’s not a problem honestly ::: )))
View Napaman's profile
Napaman
5526 posts in 4101 days
#7 posted 09-10-2011 02:44 AM
i have no idea…but cant wait to see the results…
-- Matt--Proud LJ since 2007
View Roger's profile
Roger
20928 posts in 2828 days
#8 posted 09-10-2011 03:46 AM
I’m sure there is something magnificent waitin to get outta there.
View sandhill's profile
sandhill
2128 posts in 3948 days
#9 posted 09-10-2011 05:29 AM
A house down the street has 3 trees with a few of those each on each tree and they kind of grow in a spiral I live in Florida but I do not know what they are called.
shipwright
#10 posted 09-10-2011 08:03 PM
cr1, Thanks for suggesting the obvious. I had just passed it off as not very interesting looking in the rough and assumed that the good stuff was nearer the outside.
I did as you said and this is what it looks like:
The usable area if sliced into veneer would only be about 4” x 6”, but I could get maybe ten slices.
On the other hand, there are two, maybe three turnable chunks.
Still looking for guidance.
shipwright
#11 posted 09-10-2011 10:28 PM
Thanks to all who contributed ideas.
I got off the fence and decided that since I’m more of a veneer guy than a turner, I should slice it.
I got eleven pieces with nice figure and there are still a couple of little bulbs that I may turn.
Thanks again.
View SalvageCraft's profile
SalvageCraft
274 posts in 2550 days
#12 posted 09-12-2011 12:16 AM
That’s a burl? It looks more like the bathroom floor first time I went out drinking!
-- Jesse --
Nomad62
#13 posted 09-12-2011 04:53 PM
Definately big leaf maple. Beautiful job slicing it up!
