My favorite is (and always will be): 8 + 2 = 10. Then (and ONLY then), 5:00 + 10 = Miller Time!
Here’s one that took a bit of research. Find the angle between two faces of any regular pyramid.
cos(A) = - ((R^2 + (2 x H^2+R^2) x cos(t))/(2 x H^2 + R^2 + R^2 x cos(t)))
Find the arccosine and you’re done!
Note: I had to play with the formatting a bit, to get the formula to display correctly. LJ kept ‘interpreting’ my multiplication asterisks as formatting commands, which changes parts of the formula to BOLD, AND leaves out the asterisks. Does anybody know how to suppress the auto formatting, temporarily?
Anyway,
A= the angle between the faces (the number I needed)
and I knew
R= the distance from the center of the pyramid’s base, to the vertices
H= the height of the pyramid
t= the angle (in deg) between the bases of adjacent pyramid faces (t=360/n where n= the number of faces – e.g. for a hexagonal pyramid, t=60 deg)
This works for any ‘regular’ pyramid, regardless of size, or number of faces—think gazebo roof. I got tired of punching the numbers into a calculator, so I put the formula into an Excel spreadsheet. Enter those three pieces of info, and it calculates the rest.
If you’d like a copy of that Excel file, let me know.
The formula came from, http://mathforum.org/library/drmath/view/55203.html. They explain this more better than I can.
-- There is nothing in the world more dangerous, than a woodworker who knows how to read a micrometer...
