Easy to make Tapering Jig (table saw angle cutting)
Forum topic by Angela posted 09-09-2011 05:51 AM 86537 views 6 times favorited 12 replies Add to Favorites Watch
View Angela's profile
Angela
205 posts in 3133 days
09-09-2011 05:51 AM
Topic tags/keywords: taper jig cutting angles table saw jig
Over the weekend I needed a tapering jig. I ususally purchase stuff like this because I want to spend time building other things but this was too easy not to make. I will be adding a lip on the end of the left leg. The end of the board, which is being tapered, will rest on this piece. The extra piece allows to board to move with the taper jig through the saw blade on the table saw. I had to use it to cut a very large angle so I didn’t add the lip when I took the photo.
If you’re interested in making this, I put the instructions and photos on my website.
Angela
-- www.WoodWorkersWebsite.com - Helping other woodworker's
12 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3306 days
#1 posted 09-09-2011 06:13 AM
I’ve used several of those – some home made and others store bought. My only problem was keeping everything going in the right direction. – lol
I have 16 legs to taper tomorrow. Should be a bit of an adventure. – lol
View Tootles's profile
Tootles
808 posts in 2739 days
#2 posted 09-09-2011 11:49 AM
You beat me to it! I have plans drawn up to make a jig something like this, and now everybody will think I’ve copied yours. That’s okay, I have a few differences in my design.
A question about length though. I too had planned on 24” legs but I have been worrying that might be too long. Have you found 24” to be workable? Thanks
-- I may have lost my marbles, but I still have my love of woodworking
View 1yeldud1's profile
1yeldud1
301 posts in 3279 days
#3 posted 09-09-2011 07:28 PM
If the woodworker would add a “lip” on the left leg wouldnt that stop the problem of a kickback ????
View BTKS's profile
BTKS
1989 posts in 3702 days
#4 posted 09-14-2011 04:49 PM
Cessna, please post the sled you’re talking about if you have one handy. I’m curious because I’ve just about built one of these. If a sled is better then I’d better go with that.
Thanks for the input.
GPDMTR25, thanks for getting the thread going. I like the jig but I’ve got to see available alternatives, it’s just in my nature to investigate. Sorry for stealing your thread.
Thanks, BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
Tootles
#5 posted 09-15-2011 02:33 AM
An alternative sled-style tapering jig that you may want to look at is this one. It’s really good, really versatile and should be pretty safe (I do believe the wood being cut should always be in contact with the back of the sled so that it cannot slip backwards).
The reason I like Angela’s style of tapering jig is because my table saw is a Triton Workcentre with a 7 1/4” circular saw. Firstly, the Triton table puts some restrictions on the length of sled that I can use. Secondly, until I can upgrade my saw to one with a 10” blade, the base of the sled reduces the thickness that I can cut.
View jumbojack's profile
jumbojack
1685 posts in 2861 days
#6 posted 09-15-2011 02:46 AM
I built this jig from Charles Neil; http://charlesneilwoodworking.com/references/taperjig.pdf
I have use it countless times. It cuts flawless tapers, is more than simple to build and use and is not limited to tapers. Check it out.
View BTKS's profile
BTKS
#7 posted 09-15-2011 06:58 AM
Cessna: Your description has summed up all my questions. Thanks, sounds like a viable, safe solution. Your description sounds like jumbojack’s charles neil sled. Neil’s looks a little more complicated.
Thank you all for the advice.
View SSMDad's profile
SSMDad
395 posts in 2834 days
#8 posted 09-15-2011 11:18 AM
Kickback can happen despite having the best-made jig there is. At least with this it would be at an angle (hopefully) away from the worker. Just my $.02 but I thought Angela’s was pretty good for a quick made necessary jig.
-- Chris ~~Who controls the past controls the future. Who controls the present controls the past."
View BTKS's profile
BTKS
#9 posted 09-15-2011 04:17 PM
Cessna: Wow, that’s incredible for “whipped up” sketches. Thanks for the effort and input!
Sawkerf
#10 posted 09-15-2011 06:26 PM
I made a quick and dirty sled-style tapering jig for my the 16 legs I did last week, and it worked like a champ. I liked it well enough to make a more permanent (and prettier) jig for future use.
IMO, the sled-style jigs are much more stable than the “A”-frame style.
1yeldud1
#11 posted 09-16-2011 03:42 AM
Well “CessnaPilotBarry” I’d have to agree that youare correct and i was wrong. I was looking at a “one cut” jig not thinking of a situation where you would make seveal items. Your sketch makes sence. Thanks for the reality check – it is Fun to have to put the old brian to work once in a while !!!! Thanks !!!
View gfadvm's profile
gfadvm
14940 posts in 2927 days
#12 posted 09-16-2011 03:58 AM
Cessna – That is an incredible sketch! I envy you your computing talent. Thanks for posting this. I’ll have this made before the weekend!
