Bosch router table help
Forum topic by lynng posted 09-09-2011 02:54 AM 1396 views 0 times favorited 2 replies Add to Favorites Watch
View lynng's profile
lynng
11 posts in 2682 days
09-09-2011 02:54 AM
I just purchased the Bosch RA1171 Cabinet router table to use until I can build my own. The table mounting plate does not fit my Triton MOF001C router. It seems to be an odd size plate (9×11 7/16) , so when I looked for a blank plate I could not find one. The manual says that Bosch sells a blank plate, but several reviews say they don’t and I could not find one online ( I will call Bosch tomorrow ). Drilling the existing plate is an option but there are a number of predrilled holes in the way so it will be messy.
Does anyone have a Triton mounted to this table. Any thoughts would be greatly appreciated.
-- Lynn, Trenton Maine
2 replies so far
View PurpLev's profile
PurpLev
8547 posts in 3854 days
#1 posted 09-09-2011 03:07 AM
each router mounts differently, there are only a few routers out there with similar mounting holes. the bosch router able is probably predrilled for the bosch router which is very different than the Triton (I have both so I know).
I personally would probably just redrill the existing plate unless you plan on selling it, or using it with a bosch router in which case I’d just use the existing plate as a template and make another one.
View meikou's profile
meikou
115 posts in 3840 days
#2 posted 09-09-2011 04:52 PM
I have the same table and mounted a craftsman router. The craftsman doesn’t match the hole patterns either. I set it up where to use one of the holes and then pivoted it around until I had a place to drill the other ones.
The blank plate is something that I’ve never seen in stores so you might end up waiting quite a while.
