router bits
Forum topic by matttaylor posted 131 days ago 124 views 0 times favorited 5 replies Add to Favorites
View matttaylor's profile
matttaylor
2 posts in 134 days
131 days ago
Topic tags/keywords: question
i have some but not much experience w routers. so i recently bought a porter cable plunge or fixed base, and was wondering what everyone would recommend as far as bits? one guy i know told me the 66 bit set from woodline for about 200$ would be a great start- i appreciate any advice!
View GaryK's profile
GaryK
8392 posts in 423 days
131 days ago
I think you will get all the advice you need to make up your mind here:
http://lumberjocks.com/topics/2135
teenagewoodworker
1889 posts in 203 days
131 days ago
you could get a big starter set like that and find your preferences. then get better bits from there. I have bits from Amana Tool and they are AMAZING!!!! I don’t even have to push the router. It’s like they are gliding through butter. If you want great bits I’d go with those.
View Paul D's profile
Paul D
1921 posts in 183 days
131 days ago
Matt, I recently asked a similar question and the thread Gary is pointing you to should help a lot. I’ve had my eye on that Woodline set but I’ve decided I really don’t need it. If you are going to buy Woodline bits, you might check Amazon via the LJ Store and wait if you can until they are on sale.
-- Paul D, Atlanta GA
View gerrym526's profile
gerrym526
65 posts in 243 days
130 days ago
When I bought my first Porter Cable 690 14 years ago, I went through the same decision process regarding a set of router bits. I resisted the urge and was glad I did.
Instead, buy the bits as you need them for projects. The money stays in your pocket longer, the bits you buy are exactly what you need (and you get experience in set up and use on projects), and you end up with very high quality bits (each costs a little more than the ones you get in a set, but you buy fewer). You also don’t have a lot of bits you never end up using.
I wanted to say that you end up with fewer bits, but I’d be lying-LOL! You may also end up with not only more bits, but more routers (I now have 5!).
-- Gerry
View John Gray's profile
John Gray
562 posts in 320 days
128 days ago
Get the ones with 1/2” shanks when possible. The 1st ones I bought and didn’t know the difference and got 1/4” shanks. 1/4” shanks tend to chatter more than 1/4” ones.
Bookmark And Share This Page
