Resaw Sled and Bandsaw Drift
Forum topic by MOJOE posted 09-07-2011 01:35 AM 1921 views 0 times favorited 2 replies Add to Favorites Watch
View MOJOE's profile
MOJOE
558 posts in 3466 days
09-07-2011 01:35 AM
Put together a quick sled today to resaw a few logs…..got to thinking? If I run the base of the sled through the blade (with runner in miter slot) will I get an even thickness slab if I referenced the upper portion of the sled to the cut line, ie. measure back at each end of the base (closest to blade)? Or will I need to somehow compensate for the drift angle in addition to measuring from the cut line?
joe
-- Measuring twice and cutting once only works if you read the tape correctly!
2 replies so far
View TheDane's profile
TheDane
5545 posts in 3860 days
#1 posted 09-07-2011 01:52 AM
Joe—Just a WAG, but I would think you would still have to compensate for drift. The blade is going to encounter a lot different resistance going through the log than it did just cutting the bed of the sled.
—Gerry
MOJOE
#2 posted 09-08-2011 04:22 AM
@cr1…..how exactly do you determine your blade is tensioned to 20k pounds??? I’ve recently read to adjust the tension spring 1 setting higher than the width of your blade…..in my case, set tension for 5/8” blade per tension gauge (I run a 1/2” timberwolf).
