shelf pins??
Forum topic by Belg1960 posted 09-06-2011 03:32 PM 1220 views 0 times favorited 5 replies Add to Favorites Watch
View Belg1960's profile
1061 posts in 2995 days
09-06-2011 03:32 PM
Topic tags/keywords: question
I’m looking at buying a jig and center drilling bit for this but don’t know what is more popular in the states. I would think 1/4” but I’ve been fooled before.
-- ***Pat*** Rookie woodworker looking for an education!!!
5 replies so far
View Gene Howe's profile
Gene Howe
10242 posts in 3358 days
#1 posted 09-06-2011 03:48 PM
Lots of folks, me included, make a jig from perforated hard board…peg board….And, 1/4” is pretty standard.
Another jig can be made from plywood with holes cut in to accommodate a router collar and a 1/4” spiral bit. That jig may take a little time to build, but man, is it fast, clean and accurate.
View devann's profile
2246 posts in 2622 days
#2 posted 09-06-2011 04:11 PM
1/4” holes and pins are easier for me to deal with. 5mm is the other size commonly used. The problem with the 5mm is finding a 5mm bit that doesn’t require a 3/8” chuck for the router. I like the ease of the self centering drill bit method.
View Tennwood's profile
112 posts in 3111 days
#3 posted 09-06-2011 04:30 PM
I prefer the 1/4” but both pin sizes seem to be easy to find at the hardware stores. If you are thinking of buying a jig, I got the Woodpeckers’ shelf pin template jig and really like it. After battling through home made jigs (peg board) and a cheap plexiglass one from Eagle and getting holes out of alignment, this one is real easy to use, accurate, heavy duty, accommodates drill or router, and set up for both 5mm and 1/4”. The only draw back is that it is set up for a max depth of 2-1//2 inches from the edge of the board.
-- Jim, SE Tennessee, "Don't spare the kindling Dear, we have plenty"
View Sawkerf's profile
1730 posts in 2998 days
#4 posted 09-06-2011 05:16 PM
I have the Rockler 1/4” jig and it works great.
-- Adversity doesn't build reveals it.
View pmayer's profile
1020 posts in 2995 days
#5 posted 09-08-2011 06:07 AM
I also have the 1/4” jig from Rockler. Does a great job every time. I wrote a review of this a while back:
-- PaulMayer,
