Tabletop Leveling/Adjusting
Forum topic by brukilla posted 09-05-2011 08:25 PM 1213 views 0 times favorited 3 replies Add to Favorites Watch
View brukilla's profile
brukilla
74 posts in 3267 days
09-05-2011 08:25 PM
Topic tags/keywords: level tabletop question
I will be building a torsion box tabletop to sit on some type of base. My garage floor, as far as being level, is an absolute nightmare. Has anybody thought of an easy way to level the table top instead of the entire cabinet from the bottom casters. I want the ability to fine tune the top leveling when it is to be used as an outfeed table (or at least on the same plane as the tablesaw – which will be different at any/every point in the garage.
This will be a mobile base. Everything in my shop has to move and pivot.
Why the torsion box – severe humidity changes will ruin any tabletop over a little time. I want it to last.
I appreciate any help and ideas.
-- "Determine never to be idle. No person will have occasion to complain of the want of time who never loses any. It is wonderful how much may be done if we are always doing." - Thomas Jefferson
3 replies so far
TopamaxSurvivor
18286 posts in 3700 days
#1 posted 09-05-2011 08:30 PM
Threaded rod sufficiently long enough to cover the variations.
13606 posts in 3365 days
#2 posted 09-05-2011 08:56 PM
here are self adjusting levelers
happens when you move the table
sometime just need to wiggle it
and they lock
i’ve used them for dining tables over tiles before
work great
(this is a pdf file but loads and opens fast)
http://www.levelingmounts.com/catalog/selflevel.pdf
here is another (not pdf)
View Sawkerf's profile
Sawkerf
1730 posts in 3093 days
#3 posted 09-05-2011 10:16 PM
My TS and workbench/outfeed table aren’t level and I don’t even try to level them. They are, however, flat and that’s all I really need.
The saw sits in a mobile base (although it’s never moved), and the table has adjustable feet on each leg. I used my 8’ straightedge to adjust the table feet to be coplaner with the saw table.
