What's wrong with my first finial?
« back to Woodturning forum
Forum topic by Avi posted 11-21-2018 06:59 AM 540 views 0 times favorited 9 replies Add to Favorites Watch
View Avi's profile
Avi
21 posts in 444 days
11-21-2018 06:59 AM
Been turning for about a year now, and tried my first finials on a couple of small thin boxes meant for holding spice. (about 1.5 inch wide, each)
Overall the effect looks weird. Something in the design is off. I am thinking if just cutting them off…
Advice?
9 replies so far
View AlaskaGuy's profile
AlaskaGuy
4797 posts in 2511 days
#1 posted 11-21-2018 08:32 AM
You didn’t use Alder did you?
View Avi's profile
Avi
#2 posted 11-21-2018 11:08 AM
You didn t use Alder did you?
- AlaskaGuy
Ash, walnut and I ran out so a strip of oak.
View waho6o9's profile (online now)
waho6o9
8524 posts in 2779 days
#3 posted 11-21-2018 01:15 PM
The one on the left looks fine but the right one doesn’t have the same proportion
as the left one does. Maybe shave a little off the top on the right one?
Finials are tricky to get that look that matches. It’s subjective no doubt, you’ll get there.
View Wildwood's profile
Wildwood
2478 posts in 2337 days
#4 posted 11-21-2018 01:17 PM
Have nothing to be ashamed of pretty good effort on your finials. Perhaps if do a search for turning small wood finials might find more pleasing design.
Big part of design is function, would a bead at the top be more practical for removing tops?
Been turning lot of years and might turn couple different style of finials before getting one to fit the design and function as desired. Turning small and getting crisp design elements not always that easy. I use a lot of scrap wood for practice!
-- Bill
View jbay's profile (online now)
jbay
2885 posts in 1101 days
#5 posted 11-21-2018 02:28 PM
I don’t see anything wrong with them.
If I had to change anything it would be the tops, compared to the bodies. (switch the designs)
It seems like the design on the one on the left would be a better fit for the one on the right and visa versa.
View Ripper70's profile
Ripper70
1165 posts in 1111 days
#6 posted 11-21-2018 02:39 PM
Advice?
- Avi
I agree. I don’t think the shape of the finials is the problem but rather the effect, as you say, of the contrasting colored wood. I’d cut them off.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View GR8HUNTER's profile
GR8HUNTER
5139 posts in 915 days
#7 posted 11-21-2018 02:59 PM
left one is perfect one on the right is ok just knock of the very top and it will look as good as one on left maybe try a FABRONACCI Gauge next time GREAT JOB :<))
View lew's profile
lew
12434 posts in 3958 days
#8 posted 11-21-2018 08:40 PM
A couple of videos on finials
https://youtu.be/4N9atWFUVgY
https://youtu.be/qUAcFc8zGfY
View HokieKen's profile
HokieKen
7127 posts in 1341 days
#9 posted 11-21-2018 09:37 PM
- GR8HUNTER
I was similarly gonna suggest you use the golden ratio to do your spacing and diameters. I often find that when something just doesn’t “look quite right”, applying that ratio to the design resolves the issue I couldn’t quite put my finger on.
I would also agree with Ripper that in this case, the laminated blanks may just be too “busy” for the finials.
All that being said, I still don’t think either of these look horrible. In fact, I quite like the one on the left. I think the one on the right is probably too long and the fact that the spacing between the beads at the top is wider than the spacing between the bottom beads is what makes it “look off”
-- Kenny, SW VA, Go Hokies!!!
