Help with burning 1/4 sawn white oak
Forum topic by cso posted 09-04-2011 08:41 PM 1649 views 0 times favorited 6 replies Add to Favorites Watch
View cso's profile
cso
82 posts in 2653 days
09-04-2011 08:41 PM
Hello, I was wondering if anybody had any tips on this. I am cutting bevels at 27.5 degrees and when I rip the boards, I’m not getting burns. However, when I crosscut the same bevel (almost like a raised panel look) I get burn marks. I’m using a tenoning jig for the cross cuts and I double checked that my blade is parallel to the miter slots. It’s parallel to the fence also, but that’s not the issue. I’m not getting burns when I’m normally crosscutting with the miter gauge at 90 degrees. I have changed feed rates, faster is a little better but still some burns. Thanks.
View Minorhero's profile
Minorhero
373 posts in 2570 days
#1 posted 09-05-2011 12:16 AM
I get the same as well quite often. Some woods/grains are more prone to it as well. If its an exposed piece then I have found taking a very small cut removing less then the width of your saw blade removes most if not all of the burns.
View Grandpa's profile
Grandpa
3259 posts in 2641 days
#2 posted 09-06-2011 04:41 AM
White oak is hard wood and the right tools need to be used. How many teeth are on that blade and it is really sharp or have your used it for awhile? A rip blade (fewer teeth than a cross cut blade) should be used. If you are using a cross cut blade you will have to slow the feed rate to make it cut and then you get the burning. That is where I would go.
TopamaxSurvivor
18247 posts in 3641 days
#3 posted 09-06-2011 06:17 AM
Will the premium quality carbide combo blades rip it without burning or should a ripping balde be used?
Grandpa
#4 posted 09-07-2011 05:36 AM
White oak is hard and the rip blade would probably do a better job on it. a good combo blade might be okay but most of us like to have a 10 inch blade with 60 or 80 teeth and wand to make nice smooth rips with it. It just doesn’t happen. Things start to heat up.
TopamaxSurvivor
#5 posted 09-07-2011 08:33 AM
I just googled and found this http://www.woodcraft.com/Product/2020955/23379/Forrest-WW10206125-Woodworker-II-Rip-Blade-Alt-Top-Raker-10-x-20-Tooth-ATB-125.aspx Is something that what most guys use when they have a lot of hardwood to rip? I’m an old softie;-)) Haven’t used much hardwood.
View cso's profile
cso
#6 posted 09-07-2011 12:25 PM
Thanks for all of the suggestions. I will try them this weekend. I am using a Freud LU88 thin kerf crosscut blade only used weekends and is about 8-9 months old. Cuts great and clean all around except in this case. I have a rip blade I’ll try. Thanks again, I’ll keep you posted what works.
