So I've been using clips to attach table tops to bases but am looking for a better way to attatch bench tops too. Are the clips from Rockler suitable for benches too or would the abuse from moving them and sitting on them cause them to come separated? Any ideas? Thanks
Depends on your design and how the bench base is constructed. Usually, bench legs are mortised into the top or firmly affixed by some other method. Usually wood movement is not an issue. How are you planning to build it?
You could use large dowels to connect the bench top to the base, either blind or with plugs to cover the holes. The attachment method should be as strong and rigid as the bench top or the base assembly.
Hold up guys the responses look like they're talking about workbench tops which is what I thought too but OP mentioned moving and sitting on them so I'm assuming he meant a different type of bench
My $0.02 is that tabletop clips would work fine, however figure 8 clips may be a better choice
Wholesalestunna, Maybe you could post a picture of the bench so we can give better answers.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
