Forum topic by MsDebbieP | posted 09-04-2011 01:21 PM | 2835 views | 2 times favorited | 32 replies | ![]() |
Topic tags/keywords: snipe tips tricks What are your “tips and tricks” (and challenges) re: SNIPE
Gateway to all Tips & Tricks Topics -- ~ Debbie, Canada (https://www.facebook.com/DebbiePribeleENJOConsultant) |
32 replies so far
#1 posted 09-04-2011 01:53 PM |
either make the boards longer and cut it off or sand it off i do lift the boards going into if i have many to do -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#2 posted 09-04-2011 02:36 PM |
If your planer is adjusted correctly you shouldn’t be getting allot of snipe…but David is correct…I always end up cutting off the first few inches of any board due to splitting of the wood near the ends. I get almost no snipe with my planer and butting boards together practically eliminates it except for the first and last. When I am doing a final flattening of a cutting board I like to use a scrap piece on the front and back so the finished piece doesn’t get sniped and blown out on the ends. Even the large 30 year old planer at my hardwood dealer snipes the boards..pretty good too..I always had to account for that when sizing jobs before I got my own planer. -- http://www.facebook.com/pages/DSO-Designs/297237806954248 |
#3 posted 09-04-2011 03:02 PM |
and what is snipe? From my experience, this is my understanding: When running a board through a planer the wood will shift near the end and the planer blades dig down deeper into the wood leaving a gouge and thus the wood is no longer level and smooth. -- ~ Debbie, Canada (https://www.facebook.com/DebbiePribeleENJOConsultant) |
#4 posted 09-04-2011 03:10 PM |
I also lift the boards up as I put them in and take them out especially on shorter boards. Some shorter boards I lift them up when they go in and use a long thin push stick to push it out so it doesn’t have time for snipe at the end. Long enough stick to keep my hands well away from the in feed area. |
#5 posted 09-04-2011 03:12 PM |
I have a “random snipe” planer. I get noticeable snipe occasionally and I have never determined why I sometimes get it and usually don’t. If the project is important I will cut my boards 3-4” longer than I need so I can cut off the snipe. If the piece I am working on is a little less important, I will not add the extra length and plan on sanding out any noticeable snipe. FWIW – It seems like my 10 year old planner (DeWalt 733) is sniping more now than when it was newer. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#6 posted 09-04-2011 07:44 PM |
Patron is correct . “avoiding snipe on a cheap planer ” for some pics here under ‘Planer tricks’ . My laptop has snipe ! |
#7 posted 09-04-2011 07:55 PM |
#8 posted 09-04-2011 08:22 PM |
Moment.... You can always go back and “Edit” your original post and fix things, etc. ... ( You have 60 minutes to make any changes you want to make.) Edit: ... to actually Make a 12 inch Jointer!
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#9 posted 09-04-2011 08:30 PM |
I almost forgot…....Debbie , you are doing a great job with your topics as always ! Thanks . |
#10 posted 09-04-2011 08:34 PM |
Tried that twice Joe…....no worky …..must be the weather ! Thanks. |
#11 posted 09-04-2011 08:40 PM |
moment... When you have links to fix, it’s easier to remove the OLD coding (except for the Text “Here” in this case) then, highlight the text and Click the Link Chain… then Paste the new link… etc.. -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#12 posted 09-04-2011 09:00 PM |
Thanks Joe . Now I see what i was doing wrong . I will send you a consulting fee when I win the lottery…if I live that long . |
#13 posted 09-04-2011 09:07 PM |
OK… Very good! I think you will live longer than I will! LOL -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#14 posted 09-04-2011 09:25 PM |
Don’t know about living any longer than you Joe ! LOL But there is always Bingo ! I guess I’ll head on down to the Bingo hall and see if I can cover your fee sooner . I’ll be in touch . : )I’m no spring chicken myself . |
#15 posted 09-04-2011 10:02 PM |
That was GOOD! Thank you! I’m 75… -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
