Lathe Turning and Stools?
« back to Woodturning forum
Forum topic by EM3D posted 11-19-2018 05:47 PM 531 views 0 times favorited 9 replies Add to Favorites Watch
View EM3D's profile
EM3D
3 posts in 1603 days
11-19-2018 05:47 PM
Topic tags/keywords: question lathe stool safety turning
How many of you use a stool while turning? Do you move it around frequently? Is a sit down or a lean-to type stool (similar to bass fishing boat seats)? I’m concerned it may be a safety issue? Those of you that use one, have you had issues with yours? Would you mind sharing images of what you use?
I’m considering making or modifying a store bought version for someone that is having some leg and back issues. I know they are frustrated and down about not being able to be in the shop as frequently lately.
thanks for any input or suggestions too!!
-- “The details are details. They make the product. The connections. It will in the end be these details that give the product its life.” Charles Eames
9 replies so far
View RobHannon's profile
RobHannon
189 posts in 731 days
#1 posted 11-19-2018 05:51 PM
May work with smaller pieces, but a lot of the consistency you get for cuts is moving with your stance/hips instead of moving your arms.
View DDJ's profile
DDJ
34 posts in 341 days
#2 posted 11-19-2018 11:03 PM
I know it’s done. Robust-I believe-makes a lathe for people with just those kind of disabilities. That would be an expensive way to go tho. Maybe a bench the length of the lathe bed and at the proper hieght. I thought of a chair on rollers but the floor would have to be kept clean and I know that wouldn’t work in my shop. Hope you can come up with something.
Dave
MrUnix
7046 posts in 2399 days
#3 posted 11-19-2018 11:10 PM
I use a stool for my metal turning lathes. Never for the wood turning ones though, as I move my whole body to control the tools most of the time.
View Woodster73's profile
Woodster73
20 posts in 1275 days
#4 posted 11-21-2018 05:39 PM
I use one at times, typically when I’m doing smaller or finish cuts. I find it helps a ton to relieve the low back and foot issues even if it’s only for a few minutes. I haven’t felt any issues or safety concerns. If I’m working deeper into a piece or roughing, I wouldn’t sit.
View Karda's profile (online now)
Karda
1319 posts in 754 days
#5 posted 11-22-2018 12:31 AM
I have considered it but haven’t had to yet however I do use a stool when I am sanding that helps a lot. I saw a video by richard Raffin where he talks about that. He said he use a stool for small bowls and spindle work
View socrbent's profile
socrbent
687 posts in 2470 days
#6 posted 11-23-2018 03:12 AM
This video may be helpful – https://www.youtube.com/watch?v=MckbwYye-Sg&ab_channel=WoodworkersJournal
-- socrbent Ohio
View bigJohninvegas's profile
bigJohninvegas
515 posts in 1662 days
#7 posted 12-06-2018 12:33 AM
the robust scout lathe is designed to be used while seated. Check it out.
http://www.turnrobust.com/lathe-overview/scout/
-- John
View 9x9's profile
9x9
89 posts in 1440 days
#8 posted 12-07-2018 03:16 AM
The Robust Scout lathe “STAND” (which can be used for most bench top lathe) is designed to be used while seated or standing.
-- Youngsville, LA
View 9x9's profile
9x9
#9 posted 12-07-2018 03:27 AM
My shop stool has a triangle shape seat which is comfrotable and less pressure on leg thighs.
BUT don’t use it with lathe.
-- Youngsville, LA
