Table saw platforms?
Forum topic by optimusprimer92 posted 11-19-2018 05:02 PM 271 views 0 times favorited 4 replies Add to Favorites Watch
View optimusprimer92's profile
optimusprimer92
39 posts in 762 days
11-19-2018 05:02 PM
Anyone here build a platform for their table saw? If so, could you post a picture of what you did? I’m looking at getting a cabinet saw but they average around 34” in table height. My workbench is 37” high and I’m not going to build a new one or chop I down (I use my bench for outfeed as well). The only option I can foresee is building a platform for the saw to sit on. Ideas?
View hkmiller's profile
hkmiller
108 posts in 281 days
#1 posted 11-19-2018 07:16 PM
A mobile base would give you some height
-- always something
View jonah's profile
jonah
1920 posts in 3498 days
#2 posted 11-19-2018 07:23 PM
It won’t give you 3” though. For that you’d have to either put a couple pieces of plywood down inside the mobile base for the saw base to sit on (and then you’d likely want to bolt it down to the wood), or just build a small platform out of plywood for the saw to sit on.
Personally, I need my saw to be mobile so I just adjusted my workbench height down an inch (mine was closer to 36” and my saw is 35” with the mobile base).
View MT_Stringer's profile
MT_Stringer
3183 posts in 3430 days
#3 posted 11-19-2018 07:43 PM
With my luck, I would trip on the platform while operating the saw and cause a bad accident.
View SASGeek's profile
SASGeek
8 posts in 41 days
#4 posted 11-19-2018 07:51 PM
I had the same issue with my UniSaw I simply made a base out of MDF traced the base on the platform. I removed the base and cut it along the lines that I had put on it, using a jig saw and replacing it beneath the saw. It worked fine and continues to hold my saw at the correct height. It has been almost 10 years.
I hope that this helps.
Dick
-- Dick Shryock, on the rock bound coast of Maine
