Foley Bella’s 984 Hard to Raise and Lower
Forum topic by Bwags53 posted 11-18-2018 11:15 PM 244 views 0 times favorited 3 replies Add to Favorites Watch
View Bwags53's profile
Bwags53
4 posts in 297 days
11-18-2018 11:15 PM
Topic tags/keywords: planer question
I just picked up a 985 Foley Belsaw for $100. It’s in great shape but the raise and lower is really hard to turn. I believe this was sitting for close to 2 years. Does anybody have any advice on how to fix this problem?
3 replies so far
View Planeman40's profile
Planeman40
1310 posts in 2966 days
#1 posted 11-19-2018 03:49 PM
Just oil all of the moving parts. I have a Belsaw planer from the early 1970s. The basic design hasn’t changed since the 1930s/1940s so mine and yours should be the same inside. And yes, the hand crank that raises and lowers the table is normally a little hard to turn. The mechanism has a tight chain drive and four large screws in addition to the heavy bed to move. Its the way its made. Just grab that big handle/crank and crank ‘er around!
Bwags53
4 posts in 297 days
#2 posted 11-19-2018 05:56 PM
Thanks for the response. I’m thinking that it’s stiffer than normal because it hasn’t been used in a while. I will continue to oil it and work it. Right now I have to use my body weight to turn it and that is to lower and raise it. I do feel like it has loosened up a little.
Planeman40
#3 posted 11-20-2018 05:12 PM
It might also require cleaning the mechanism. Sawdust can get into the workings over time.
