Have any of you tried this stuff?
Forum topic by lilredweldingrod posted 09-03-2011 08:30 AM 2479 views 0 times favorited 11 replies Add to Favorites Watch
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3069 days
09-03-2011 08:30 AM
I’ve been using this Penetrol 90 from Shaeffer Oil since 1989. It is a fantastic cutting oil, penetrating oil, rust desolver, and lubricant.
To give you an idea of how good it is, I needed to cut the ends off 4 3/4” grade eight u-bolts on a Western Unit suspension on a gasoline trailer. In cutting the first bolt, I used 5 bi Metal blade in my sawzall. At a buck 65 each, this got expensive fast. I used Penetrol 90 on the rest of the cuts and when finished, I still have a good blade.
I have taken rusty bearings and worked them with the Penetrol 90 and after cleaning them up found them usable to put right back if not pitted.
This is not available in stores, and you must deal with a Shaeffer salesman. You can go to them on the internet and they will hook you up. http://Shaefferoil.com
And NO silicone to mess up your wood.
11 replies so far
View rance's profile
rance
4255 posts in 3123 days
#1 posted 09-03-2011 08:44 AM
Interesting, and thanks for posting. Now GO TO BED, it is 2:45am !!! :)
lilredweldingrod
#2 posted 09-03-2011 08:47 AM
Wrong, Rance. It’s only 11:46 here. What in the cat hair are you doing up at your hour? lol
TopamaxSurvivor
18244 posts in 3638 days
#3 posted 09-03-2011 09:22 AM
This stuff is much better than Liquid Wrench, eh?
View Rob200's profile
Rob200
313 posts in 3131 days
#4 posted 09-03-2011 04:19 PM
I love the stuff
-- Robert Laddusaw and no I am not smarter then a fifth grader ( and no I canot spell so if it is a problem don't read it ))
View GaryCN's profile
GaryCN
322 posts in 3897 days
#5 posted 09-03-2011 04:44 PM
I’ve been using PB B’laster
-- Quando Omni Flunkus Moritati
View jusfine's profile
jusfine
2422 posts in 2888 days
#6 posted 09-03-2011 05:46 PM
Never heard of it, will check out the link. Thank you!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3078 days
#7 posted 09-03-2011 06:27 PM
sounds like a goood idea …thuogh I´m not fammiliair with the brand
I will look out for something like that here … thank´s for the tip :-)
Dennis
View Joe Lyddon's profile
Joe Lyddon
10045 posts in 4015 days
#8 posted 09-03-2011 07:35 PM
I went to the website… Finally Searched for ” Penetrol 90” ... got a ton of ” Penetrol” links… nothing on ” Penetrol 90”...
Can you give me a link where I can get it?
View DrSteve's profile
DrSteve
34 posts in 2812 days
#9 posted 09-03-2011 07:43 PM
http://www.schaefferoil.com/penetro-oil.html
This is what I found when I did a google search
Looks like you can order online however by the case. Don’t know how fast I would go through that. Although I did find a listing for single cans on ebay
Joe Lyddon
#10 posted 09-03-2011 08:07 PM
Yeah… I should’a done that 1st…
They are on eBay too… prices & shipping all over the place!
lilredweldingrod
#11 posted 09-03-2011 09:16 PM
I misspelled it. I t is Schaeffer oil products.com Sorry about that. I usually order it a case at a time and I have two friends in the trucking profession that take equal shares. at the moment I have 4 cans in stock and will go through that in about a year.
If you use it with your drills when you drill steel, you can forget sharpening them almost forever. It is fantastic for the clamp threads and stops rust on the threads. It virtually stops stainless threads form gaulding when you are tightening them.
Give me time and I will bore you to death with the good things this does. lol
