yellow glue question
Forum topic by BobD posted 09-03-2011 08:24 AM 1183 views 0 times favorited 8 replies Add to Favorites Watch
View BobD's profile
BobD
52 posts in 3381 days
09-03-2011 08:24 AM
Will yellow glue adequately glue two pieces of wood, Oak in my case, together. Usually yellow glue is applied to bare wood to achieve a good bond. If yellow glue is applied to a stained surface in the joint area will it hold? No real pressure will be applied to the joint. I’ll be using Titebond II yellow glue.
-- Bob, San Diego
8 replies so far
View David Grimes's profile
David Grimes
2078 posts in 2608 days
#1 posted 09-03-2011 09:25 AM
It will not be as strong with the stain (or anything else) in the wood fibers / cells.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View rusty2010's profile
rusty2010
150 posts in 2526 days
#2 posted 09-03-2011 02:22 PM
David is correct, the glue sticks to whatever the surface is. the queston would be. how good is the stain sticking to the wood and is the stain an oily surface. i made that mistake many years ago. the piece broke apart and i had to resurface the edges and start over. i would not advice it.
-- check, recheck then check again
View rogerw's profile
rogerw
262 posts in 2657 days
#3 posted 09-03-2011 02:28 PM
If you haven’t stained yet, tape off the glue area before you stain. This way you’ll still have a strong glue joint.
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
View olddutchman's profile
olddutchman
187 posts in 3903 days
#4 posted 09-03-2011 03:08 PM
If You are conserned about the surface, You can clean with a cleaner. I try to give the surface a sand with 80 grit paper, and clean dust off. It will help the glue grab a bit better!
-- Saved, and so grateful, consider who Created it ALL!!!
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3126 days
#5 posted 09-03-2011 04:56 PM
Go back to raw wood on those joints. The consequences are life-changingly apocalyptic.
-- jay, www.allaboutastro.com
View glue4you's profile
glue4you
162 posts in 2448 days
#6 posted 09-03-2011 05:23 PM
I respect the advice the others have given so far and they are right.
But:
I have occasionally used waterbased stain before glueing to get around the problem of wood not taking the stain well. I carefully roughened the surface in the glue areas and have never had any problems with it. I wouldn’t recommend oil based stains though! And what you said: “No real pressure will be applied to the joint.” should be true :-)
Good luck with whatever decision you make!
-- Alex ----- Bavaria in Germany
View Darren Webb's profile
Darren Webb
16 posts in 2430 days
#7 posted 09-03-2011 05:31 PM
I use Gator Glue for these kind of bonds. Its pretty strong stuff
-- Make Six Figures as a Pro Carpenter Expert Woodworker Reveals His Trade Secrets http://carpentryprojectplans.com
rusty2010
#8 posted 09-03-2011 07:44 PM
I think Jay is taking this a little too serious,,
