Staining fiberglass exterior door
Forum topic by BuckeyeJohn posted 11-16-2018 09:46 PM 242 views 0 times favorited 5 replies Add to Favorites Watch
View BuckeyeJohn's profile
BuckeyeJohn
10 posts in 327 days
11-16-2018 09:46 PM
I just bought a fiberglass exterior door for the front of my house. The door is an off white or cream color. The wife wants it stained a mohogany color. Is this doable? What type of prep, stain, and top coat would be recommended for this? The door will be under a covered porch.
Thanks John
5 replies so far
View ArtMann's profile
ArtMann
1132 posts in 1013 days
#1 posted 11-16-2018 10:08 PM
I have a new house with a fiberglass door. You need to try an inconspicuous area first but my door took stain just about like wood.
BuckeyeJohn
#2 posted 11-16-2018 10:21 PM
Thanks Art, the door has a glossy finish on it, will I need to steel wool it before stain?
View Eric's profile
Eric
70 posts in 70 days
#3 posted 11-16-2018 10:44 PM
I would prep the door just as you would for paint. But yes try a small spot first.
Does this door have a stamped woodgrain? If it is, it will take stain. If it is smooth, you may consider painting then.
Sherwin Williams, makes a good wiping stain which will take well on exterior doors, however you must allow it to dry overnight. Then use a good quality poly to protect the door.
-- Eric, Upstate South Carolina
BuckeyeJohn
#4 posted 11-16-2018 10:50 PM
Eric, thank you for your reply. The door is stamped wood grain, thanks for the info on the wiping stain.
View Eric's profile
Eric
70 posts in 70 days
#5 posted 11-16-2018 11:08 PM
Your welcome. I think it goes under the name of “Wood Classic” you will be able to make it light or dark as you please
