| Forum topic by Duckarrowtypes | posted 596 days ago | 2372 views | 0 times favorited | 7 replies | ![]() |
596 days ago |
I’m planning a single-drum compost tumbler that is similar to the one shown here http://www.instructables.com/id/Double-Decker-Drum-Composter/ What I would prefer to do is make an A-frame from 4×4s and a 2×6 crosspiece. The drum would be mounted on a pipe that would go through the 2×6 braces. I would prefer not to use big lag bolts and such on this project… I would prefer not to use any metal at all if I can get away with it, actually. I figured that I would miter the 4×4s so that they would join up at the top but I can’t think of a good joinery method for up there beyond a big old lag bolt. If I just bolt the 2×6 onto the 4×4s then it should be strong enough to support the weight but I don’t think that it would be very attractive. How would YOU do it? Jon -- Custom Daguerreotypes from your images and more: www.shinyphotos.com |
