| Forum topic by MikeOB | posted 623 days ago | 498 views | 0 times favorited | 5 replies | ![]() |
623 days ago |
I have the 3 main sides of a cabinet I’m working on and for some reason I’m off about a 1/16” or so too wide on my top rail of the face frame. Is a belt sander the best option here to make it even or handsanding? thanks -- Mike, Portage, WI |
5 replies so far
#1 posted 623 days ago |
If I’m understanding correctly, your faceframe is hanging 1/16” over your cab carcass. Trim it off with a flush cut trim bit in your router if you want the faceframe flush with side. That way it’s flat and square. Sanding can be a bit iffy for accuracy. -- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless. |
#2 posted 623 days ago |
I understand…my issue is when I go to put the top on it not being level…would this same method work? -- Mike, Portage, WI |
#3 posted 623 days ago |
Along Gary’s thinking, if the problem is with a side and you need to trim of the board ends, a router is still your best option. Make use of a straight edge carefully set so you only take 1/16” off. You can also do this along the face board or stretcher, but you may find clamping space at a premium for this. In this case, I would mark my cut with a knife (pencil mark is to thick) and I would use a hand plane or preferably a cabinet scraper to take that 1/16” off. That’s what I would do… I’m sure others would do differently and they may say so. Chose the method you’re comfortable with! -- Bernie: It never gets hot or cold in New Hampshire, just seasonal! |
#4 posted 623 days ago |
Bernie and Gary are about right. Sanding accurately is chancy, and sanding 1/16” is a lot of work. Steve -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#5 posted 623 days ago |
thanks guys -- Mike, Portage, WI |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15751 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
