Jet JWBS-18 Bandsaw Blade question
Forum topic by PRGDesigns posted 11-15-2018 02:10 AM 523 views 0 times favorited 6 replies Add to Favorites Watch
View PRGDesigns's profile
PRGDesigns
244 posts in 2513 days
11-15-2018 02:10 AM
Topic tags/keywords: bandsaw blades resaw
We have a Jet JWBS-18 bandsaw with a 1-1/2 HP, 120V motor. We’ve had it for a number of years and have forgotten more about the saw specs than we remembered. I was searching for a Carbide tipped resaw blade and discovered / remembered that the saw could take up to a 1-1/2” wide blade. We’ve only ever used up to a 3/4” Wood Slicer blade on this saw with success. My question for the forum is, before we invest in a $150.00 to $200.00 blade, what kind of performance can we expect with either an 1-1/4” or 1-1/2” wide blade on this bandsaw? We mostly resaw Maple and other Hardwoods. In other words, will the motor turn this blade as well as it does the 3/4” Wood Slicer? Some of the newer 18” bandsaws come with a 3HP / 220V motor, which made me wonder about our saw possibly being underpowered. Thanks in advance for any consideration you can give this matter.
-- They call me Mr. Silly
View Aj2's profile
Aj2
1873 posts in 1997 days
#1 posted 11-15-2018 02:56 AM
I wouldn’t put a blade that wide on that saw. Carbide or carbon steel.
Pick the blade with the right tooth count for the thickness of wood your cutting.
3/4 inch wide blade sounds about right for a 18 inch saw.
-- Aj
View GR8HUNTER's profile
GR8HUNTER
5108 posts in 912 days
#2 posted 11-15-2018 03:53 AM
Blade width ….................. 1/8 to 1-1/4 in.
1-1/2 is too wide for that saw :<((
View fly2low's profile
fly2low
54 posts in 296 days
#3 posted 11-15-2018 06:26 AM
I have a 5 hp 18 inch Laguna, and I can only go to 1 1/4. For yours I was thinking 1 to 1 1/4
-- Rich Gig Harbor, WA
PRGDesigns
#4 posted 11-16-2018 03:22 AM
Thanks for the input.
GR8HUNTER – Thanks for your contribution. Unfortunately, our manual for our Jet JWBS-18 Bandsaw, with a 1-1/2 HP motor, shows minimum blade width = 1/8”, and maximum width blade = 1-1/2”. However, the manual for the Jet JWBS-18, with a 1-3/4 HP motor, shows a minimum blade width = 1/8”, and a maximum blade width = 1-1/4”. We also found bandsaw blade vendor’s websites showing our bandsaw would take up to a 1-1/2” blade, confirming the owner’s manual information (attached).
View AHuxley's profile
AHuxley
853 posts in 3521 days
#5 posted 11-16-2018 08:23 AM
Keep in mind the width specs for a bandsaw are based on the width of blade the wheels and guides can accommodate not what blade widths (and types) the saw can adequately tension. For that saw I would recommend a maximum of a 3/4” carbide blade which works best in the 27k-30k psi range (basically twice the tension of the Woodslicer and the Woodslicer is also a very thin gauge blade which requires much less spring pressure for a given tension). Also remember the benefit of a wider blade is the increase in beam strength once you reach the limits of a saws ability to tension the blade properly going wider and/or thicker actually lowers the quality of the cut. To put in in perspective the smallest saws I am aware of that will fully tension a 1 1/4” Trimaster, for example, are the 24” Minimax (now Formula) and 28” Laguna, Felder and Northfield.
fly2low
#6 posted 11-17-2018 09:36 AM
You might be able to get a 1 1/2 inch resaw blade to fit – that doesn’t men it will work
