Triton Router Slipping Problem
Forum topic by unclearthur posted 11-14-2018 04:42 PM 176 views 0 times favorited 0 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
193 posts in 1987 days
11-14-2018 04:42 PM
Hi all. Looking for a little tool repair help.
I have a Triton 2 HP Router (MOF001) which is several years old but very lightly used:
Its always been used in a router table with the plunge spring removed. The problem is that the lifting mechanism is slipping, either during a cut (if the plunge lock lever is not engaged) or after a cut is finished when the plunge lock lever is disengaged. This video shows it slipping after a cut, when I disengage the plunge lock lever.
The slipping used to happen a little bit sometimes, but has recently gotten much worse.
I found some threads on LJ about Triton routers having similar problems due to a deteriorated plastic worm gear, so I contacted Triton and they mailed me out a replacement steel gear (no charge, kudo’s to them). I then partially disassembled the router:
and saw that my worm gear was already metal:
No obvious problem there.
Also, everything I can see seems OK: no obvious wear or dirt, everything looks pretty new.
Does anyone have any suggestion regarding what I should check before re-assembling?
Thanks for any replies.
0 replies so far
