need to understand how to measure for framing with 45 degree cuts
Forum topic by dexter posted 632 days ago 5092 views 0 times favorited 10 replies Add to Favorites Watch
View dexter's profile
dexter
2 posts in 632 days
632 days ago
Topic tags/keywords: pine
the how to cut a 45 degree angle is well document throughout the web.
I am unable to find a plain ez way to measure for the correct lenght of the piece.
what do I measure and how do I measure it?
I seem to always be an 1/8 th off plus or minus…
how do i get accurate measure ment…..?
10 replies so far
View Gene Howe's profile
Gene Howe
3200 posts in 1601 days
#1 posted 632 days ago
What size wood are you cutting? Are you framing a building, building a box, or making a picture frame? In other words, how precise do you need to be?
If you know the length of the piece you need, cut the first 45, then measure the long side and mark it. Remember, it’s an opposite cut. To help me, I use a saddle square that has a 45 on one leg. It gives me the right cut direction as well as a perfect line at 45.
14866 posts in 2391 days
#2 posted 632 days ago
I’m not sure if this is what you are asking, but if you cut a 45 degree angle on a board, the difference in length between the short side of the board and the long side will be equal to its width.
In other words, if you take an 8-foot 2×4 (which is 3.5 inches wide) and cut a 45 degree angle on one end, the shorter side of the board will measure 92.5 inches. (96 – 3.5 = 92.5)
Do the same to an 8-foot 2×6 (5.5” wide) and the short side will measure 90.5”. (96 – 5.5 = 90.5)
TopamaxSurvivor
13194 posts in 1848 days
#3 posted 632 days ago
Good point Charlie. I didn’t know that ;-)) I don’t quite understand the question either. Sounds like care in cutting on the line might be part of the issue with 1/8 variance.
View Grandpa's profile
Grandpa
2381 posts in 848 days
#4 posted 632 days ago
Sounds like cutting on the wrong side of the line. If he is using a miter saw and you change from one side to the other for the second cut then you need to cut on the other side of the line. A blades thickness is about 1/8 inch….?
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1287 days
#5 posted 631 days ago
if you make it 1/16 or 1/32 longer everytime and use a plane and shootingboard
to sneak up on it you get right evrytime and take care of slightly out of angle at the same time :-)
Dennis
dexter
2 posts in 632 days
#6 posted 631 days ago
thanks guys, just trying to get a handle on the “how to measure” so I can make consistent 45 degree cuts for whatever I am making.
As I understand it, I measure the dimension of what i am framing. e.g. 8 in width. make one cut, then measure the inside dimension, mark the 8 in plus 1/16 for the opposite cut.
I get the blade thickness and take it into account.
As a novice, I get confused about measuring and marking….correctly consistently.
Thanks for your help. Appreciate it.
Dan
View chrisstef's profile (online now)
chrisstef
5309 posts in 1179 days
#7 posted 631 days ago
Its a good question, and Charlie enlightened me as well. I typically leave one side a bit longer and then sneak up on it.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View PurpLev's profile
PurpLev
7764 posts in 1821 days
#8 posted 631 days ago
also, if it’s always 1/8” shorter try aligning your saw blade on the other side of the marked line. the kerf of the blade is 1/8” by itself which might explain why you are always 1/8” shorter – just a thought
View BTKS's profile
BTKS
1919 posts in 1637 days
#9 posted 597 days ago
Typically it is much easier to measure the long side of a miter. The point of the miter is a much more precise point to referece. The obtuse angle of the short side is easy to mismeasure.
I also prefer to transfer dimensions rather than measure. Every time you measure you introduce possible errors. Just on one side of the line or the other everytime you measure and every time you mark. If you can transfer the dimension, the measurement does not matter! This is why a story stick is so useful in stair or cabinet building.
Hope that made some sort of sense. Good luck, BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View Susan's profile
Susan
65 posts in 603 days
#10 posted 591 days ago
I always leave a little on the length and then nibble it down with my guillotine….doing this with each piece ensures a more accurate angle and a smoother more snugged up fit…
=0)
-- Mad Jester Woodworks, "Not what I have, but what I do is my kingdom" Thomas Carlyle
