DeWalt model 1400 radial arm saw motor won't turn
Forum topic by mcoulton posted 11-12-2018 09:20 PM 227 views 0 times favorited 4 replies Add to Favorites Watch
View mcoulton's profile
mcoulton
2 posts in 36 days
11-12-2018 09:20 PM
Topic tags/keywords: dewalt 1964 1400 motor
I bought a model 1400 DeWalt radial arm saw this weekend .
After using it for 45 minutes, smoke camo out of the box where the capacitors are located.
It no longer rubs or even hums when turns on, I hear a little click when the power is turned on.
The reset button is missing and all I see is a hole.
Is there a place to get the wiring diagram and the specs for all the parts to do a rebuild of the power box.
I like the saw because it as really heavy and there is no play when everything is locked down.
It would be cool to put in some DRO readouts on it
View mpsprunger's profile
mpsprunger
27 posts in 2066 days
#1 posted 11-12-2018 11:38 PM
The box on top, probably contains a cap, and a potential relay. The relay opens when the energy from the turning rotor is enough to energize the coil in the relay. Then it switches to the run cap. Mine had a 3 hp motor, the fellows, at the shop, connected it to 220 the wrong way w/out using the magnetic contactor and burned up the start windings. it died
MrUnix
7053 posts in 2404 days
#2 posted 11-12-2018 11:54 PM
Without any other info, you are probably not going to get more than guesses. Does the arbor spin freely when turned by hand? It could be a bad cap, which is easy to test with a multimeter in resistance mode… but it should not have fried in the middle of running. Doing so could be due to a faulty centrifugal switch stuck closed. IIRC, those models also have a blade brake, which may have malfunctioned… or you could have had a catastrophic bearing failure.
Too many possibilities, too little information. You are going to have to open it up and do a little diagnostics in order to narrow it down.
mcoulton
2 posts in 36 days
#3 posted 11-13-2018 04:07 AM
i found that it tripped the gfi.
When i reset it , there is a humming when you hit the power but the motor does not spin.
i see that it has a mallory 200-240MFD 110 VAC
i am attaching a file
5179 posts in 2699 days
#4 posted 11-13-2018 11:46 AM
You probably just need to replace the capacitor. Take that one with you to a motor shop (or industrial supply) and get a replacement. Should cost less than $20. Taking it with you is. good idea because some of them might be a little larger in size and not fit so snugly in the box.
