Online Two end log calculator
Forum topic by greenhorn712 posted 08-31-2011 11:53 PM 1900 views 0 times favorited 6 replies Add to Favorites Watch
View greenhorn712's profile
greenhorn712
6 posts in 2363 days
08-31-2011 11:53 PM
I am looking for an online log calculator which gives board feet, volume, and weight by species if possible, using both the fat and skinny end of a log. From what I’ve read online this is a “Two end conic rule?” I’m going to do some small scale logging in the near future and want to get an estimate of the yield I would be looking at before going to a mill or hiring a logger and somebody maybe trying to pull the wool over my eyes. Does anyoneknow of an online calculator using the two end rule? I’ve been unsuccessful in finding one. I’ve been able to find all kinds using only the skinny end. Thanks!
-- Nancy~~Washington State
View Barbara Gill's profile
Barbara Gill
153 posts in 2563 days
#1 posted 09-01-2011 12:31 AM
Try Woodweb.
-- Barbara
View Nomad62's profile
Nomad62
726 posts in 2861 days
#2 posted 09-01-2011 12:31 AM
go to woodweb.com, they have the exact calculator you need.
greenhorn712
#3 posted 09-01-2011 04:46 PM
Thanks Barbara and Nomad, the log volume calculator on Woodweb is perfect; but their board footage one only uses the small end of a log; I’d like to find a bdf calculator that uses both ends :-)
Nomad62
#4 posted 09-01-2011 07:11 PM
Well, I up and misread what you wrote, sorry about that. Anyway, all loggers and mills use the small end for board footage as that is the way it is cut; the bevel is considered waste as you cannot get a board out of it unless you are cutting a really long log and snip off what you can use from the cut-off. But to answer your question I would guess you could use the estimator from woodweb to get 2 measurements from full logs of each size you have, then average them; say a 20” log and an 18” log would average to a 19” log, making an 18×20 “coned” log a straight 19” log…
View WDHLT15's profile
WDHLT15
1720 posts in 2379 days
#5 posted 09-02-2011 04:06 AM
If you are looking at board feet, the log rules like Doyle, International, and Scribner only use the length and the small end diameter. If you are looking for cubic foot volume, the google smalian’s formula.
greenhorn712
#6 posted 09-02-2011 05:18 PM
Thanks Nomad62, I’ve read up some about how the mills price and while I understand they have to make their money too, I’ve thought it’s a bit of a gip for them to only use the small end, ‘cause basically they’d be getting much of the tree for free?
WDHLT15, before your reply I hadn’t seen anything mentioning smalian’s formula, thank you! Now if I can find an actual calculator that uses that instead of articles, that’ll be good :-)
