Tips & Tricks: Recycling Pallets for Projects
Forum topic by MsDebbieP posted 08-31-2011 11:56 AM 7144 views 2 times favorited 19 replies Add to Favorites Watch
18615 posts in 4279 days
08-31-2011 11:56 AM
Topic tags/keywords: pallets tips tricks
What are your “tips and tricks” (and challenges) re: using pallets for woodworking projects?
here are the links to postings here at LumberJocks.com, tagged as “pallets”.
Gateway to all Tips & Tricks Topics
19 replies so far
TopamaxSurvivor
18358 posts in 3794 days
#1 posted 08-31-2011 12:05 PM
Getting them apart is an issue with the spiral nails. Even when they do pull out, the tips are often broken off and still in the wood. A sawzall or circular saw works very well to cut clean wood from between the framing members. Recycle the iron in the ashes in the wood stove from those pieces with nails in them ;-))
View Don Butler's profile
Don Butler
1092 posts in 3513 days
#2 posted 08-31-2011 12:29 PM
I’m leery of using pallets, although I have occasionally done so.
My worry is bugs. Some pallets are infested. for that reason alone I won’t keep them around.
If I do try to harvest some exotic wood from a pallet I look very carefully for bug tracks, especially at end grain cuts.
Even domestic pallets can have critters in them.
I wouldn’t want something like powder post beetles in my wood storage room!
On the other hand, some pallets are made with some very nice hardwoods.
It’s a balancing act.
Having said all that, I don’t get access to pallets much anymore unless I buy a machine. When I was still working in industry, I could have all the pallets I wanted.
That was then, this is now. ddwwb
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View rance's profile
rance
4262 posts in 3278 days
#3 posted 08-31-2011 05:06 PM
Only ones I’ve come across have been somewhat softer wood. Not quite as soft as pine. Good for hand-cut dovetail box. Sometime pretty wood. I’ve not run across any exotics or darker woods.
I no longer pull the nails(not worth my time or machinery risk). I quickly cut them out with a circular saw and settle for shorter boards. The powder post beetles bothers me. Maybe cut up the pallet, mill all the boards, and build the project and out the door all in one day. No leftovers.
View mafe's profile
mafe
11741 posts in 3207 days
#4 posted 09-01-2011 12:55 AM
Youtube has plenty of videos on how to put them apart.
If I don’t need the whole thing, I run a old circular saw over it, as close to the nails as possible, so I only have to remove the mid nails.
Another way is to bang them through the wood with a nail punch.
Best thoughts,
Mads
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3233 days
#5 posted 09-01-2011 01:21 AM
I readed it as link to projects made of recycled wood or upcycled as some call it …. LOL
that wuold be cool to have
run a wirebrush over the wood before using it or plane it with a sander instead
Dennis
#6 posted 09-01-2011 01:31 AM
Dennisgrosen
#7 posted 09-01-2011 01:54 AM
sorry didnĀ“t remembered that one :-(
Dennis
TopamaxSurvivor
#8 posted 09-01-2011 02:56 AM
Guess I’d better tag the boyz trucks ;-))
View Darren Webb's profile
Darren Webb
16 posts in 2580 days
#9 posted 09-01-2011 11:22 PM
Great post this is
-- Make Six Figures as a Pro Carpenter Expert Woodworker Reveals His Trade Secrets http://carpentryprojectplans.com
View bandit571's profile
bandit571
21061 posts in 2801 days
#10 posted 09-02-2011 12:43 AM
I have been recycling pallets for almost 30 years now, in fact I just reclaimed some 4×4 runners from a couple of skids. Some of them, I take a splitting maul to tear them down. That way, nails and all come off the runner. Then I can resaw the runner, leaving the center as scrap, just in case. The center is about just the same width as all those nail holes.
As for those bug tracks, I seem to like them, as long as the bugs are gone. The top for that table was made from reclaimed wood. An old barn rafter, resawn into 3/4” x 3” pieces. A look at the wood before two coats of Poly gloss:
As for what nails I run into, I work around the nails. Usually rip one side of a runner( they are usually4/4 or more) and not worry about any “leftovers” that might be inside. Another table, look at the white oak aprons closely, you’ll see a few nail holes:
Most nails I find, I use a GOOD pair of Visegrips, and a rip claw hammer, to “work” the nail back out. Around here the Amish make a living building pallets from scratch, and I can sometimes pick up some of their “scrap” without the nails in them. Just an idea…
View WilsonCreations's profile
WilsonCreations
105 posts in 2649 days
#11 posted 09-02-2011 03:47 AM
I’ve started seeing crate wood in the local Habitat for Humanity RESTORE. It’s nice having them disassembled already. Yes there is a price tag on it but at $.40 to $1.00 a piece and a selection on sizes it’s a nice option. I haven’t seen any staples or obvious evidence of any treatment. I’m finding a lot of inspiration there and just need some cooler weather to get back in the shop.
-- Wilson
View Joe Lyddon's profile
Joe Lyddon
10240 posts in 4170 days
#12 posted 09-02-2011 06:14 AM
bandit571:
Great work using pallet wood! You’re doing really GOOD!
Very good Tips… from all of you…
I don’t come across very many pallets that I used to…
Darren Webb
#13 posted 09-02-2011 03:37 PM
What an amazing tip this is and what a fantastic job on those pieces of work. To be honest I’ve only used Pallet wood for my firewood, wedges etc. I can get hold of loads of these things for free, anybody interested ??
24263 posts in 3969 days
#14 posted 09-04-2011 02:06 AM
Thanks Deb. I’ll keep that one in mind.
View mafe's profile
mafe
#15 posted 09-04-2011 02:31 AM
Ohhh yes one good advice is to check for stones and nails before running through the planner, this can be expensive if your planner blades are broken.
