removing printing from PVC
Forum topic by Karda posted 11-10-2018 07:07 AM 651 views 1 time favorited 17 replies Add to Favorites Watch
View Karda's profile
Karda
1328 posts in 760 days
11-10-2018 07:07 AM
Hi, I am using pvc Piipe in a project and want to remove the printing what can I use, alcohol, paint thinner don’t work. Nail polish remover smears it but I would have to use too much to be practical, anybody have any ideas thanks
17 replies so far
View MrUnix's profile
MrUnix
7053 posts in 2405 days
#1 posted 11-10-2018 07:24 AM
Nail polish remover smears it but I would have to use too much to be practical [...]
- Karda
Can’t really help with a recommendation, but thought I’d point out that nail polish remover is basically just Acetone – sometimes with a little bit of coloring and/or perfume added. Bought as nail polish remover, you will pay through the nose for it. If that’s what is holding you back from using it, you can get gallons of it at the BORG for cheap. I believe it was around $13 a gallon at my local Sherwin Williams store last time I bought some (about 6 months ago). Also, PVC cleaner, which has always removed lettering and other stuff when I’ve used it in the past, is mostly Acetone (75%-95%).
PS: The wife hasn’t bought ‘nail polish remover’ in over a decade now. I just fill up her little 8oz bottle now and then when it runs low ;-)
View WoodenDreams's profile
WoodenDreams
304 posts in 117 days
#2 posted 11-10-2018 09:27 AM
Test a high grit sand paper
View GR8HUNTER's profile
GR8HUNTER
5168 posts in 918 days
#3 posted 11-10-2018 12:32 PM
brake parts cleaner :<))
View Hermit's profile
Hermit
211 posts in 1531 days
#4 posted 11-10-2018 01:05 PM
The purple primer takes it off immediately but you’re on your own getting the primer off. A light sand may take it off or possibly use mineral spirits, lacquer thinner etc.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
View johnstoneb's profile
johnstoneb
3064 posts in 2378 days
#5 posted 11-10-2018 02:17 PM
Lacquer thinner works well
-- Bruce, Boise, ID
View bondogaposis's profile
bondogaposis
5098 posts in 2557 days
#6 posted 11-10-2018 02:32 PM
Nail polish remover is just lacquer thinner.
-- Bondo Gaposis
5179 posts in 2699 days
#7 posted 11-10-2018 03:12 PM
Guys, I was wondering about the lacquer thinner. I have a small piece of PVC and tried the thinner on it…didn’t even smear it around. DNA didn’t either. I’m out of acetone at the moment, but it seems to me that’s what the contractors at my plant (when i had a day job) used.
Karda
#8 posted 11-10-2018 04:42 PM
thanks for the suggestions, didn’t want to use sand paper but that may work out anyway Mike
View Vicki's profile
Vicki
1106 posts in 3550 days
#9 posted 11-10-2018 05:51 PM
I use sandpaper, works great.
-- Vicki on the Eastern Shore of MD
View Planeman40's profile
Planeman40
1310 posts in 2967 days
#10 posted 11-11-2018 02:17 PM
Also try alcohol. And be aware that acetone may melt the PVC pipe surface. It melts a lot of plastics. Try some on a piece of scrap PVC first.
johnstoneb
#11 posted 11-11-2018 03:33 PM
Lacquer thinner has always taken it off for me. You said nail polish remover was working for you and that is lacquer thinner in a small bottle with a high price.
-- Bruce, Boise, ID
View xeddog's profile
xeddog
211 posts in 3213 days
#12 posted 11-11-2018 05:13 PM
I have also used an abrasive pad with some running water. If you need to keep a really smooth surface, some 600 or so wet-or-dry sandpaper under water will leave a smooth surface.
Wayne
Karda
#13 posted 11-11-2018 05:31 PM
I said polish remover smeared it but it was hard, sandpaper work better and faster and gave me the rough surface I need. I thought that nail polish remover was a weak acetone
View John Smith's profile
John Smith
1491 posts in 368 days
#14 posted 11-11-2018 06:43 PM
whatcha makin ??
sandpaper it just to get some tooth – then spray it with Krylon enamel.
-- I started out with nothing in life ~ and still have most of it left.
View roofner's profile
roofner
126 posts in 2489 days
#15 posted 11-12-2018 11:29 PM
I use acetone
