34-466 Unisaw starter question
Forum topic by CVN72 posted 11-09-2018 04:37 PM 313 views 0 times favorited 9 replies Add to Favorites Watch
View CVN72's profile
CVN72
13 posts in 255 days
11-09-2018 04:37 PM
Hi,
I just purchased a 34-466 Unisaw and would like to replace the existing starter switch with a magnetic paddle switch.
It looks like the saw originally came with a 2 HP 3 phase motor but was replaced with a 3HP single phase motor and rewired. Can I wire direclty from the motor to the paddle switch and discard the existing srtarter assembly?
How do I upload a picture from my computer to this thread?
I would also like to replace the arbor bearings and belts on the saw. Any suggestions on quality bearing for a good price? I was going to try Accurate Bearings. What specs do I give them?
Thanks.
9 replies so far
CVN72
#1 posted 11-09-2018 04:40 PM
OK, I figured out how to upload images.
View Kazooman's profile
Kazooman
1271 posts in 2193 days
#2 posted 11-09-2018 04:42 PM
For the picture. When entering the text of your comment, click on the IMG button above the top left corner of the text field. Click on “choose file”. navigate to the picture file on your computer and then click “insert file”. You can check how it comes out with the preview button before posting.
Edit: I see I was two minutes too slow to help out. Good that you figured it out.
CVN72
#3 posted 11-09-2018 04:46 PM
And some pictures of the saw. It’s in pretty good condition considering the age. It just had quite a bit of sawdust in it and some rust.
After brushing off the sawdust and vacuuming.
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#4 posted 11-09-2018 07:02 PM
Don’t replace the starter. Replace the switch. The starter has the overloads for the motor.
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#5 posted 11-09-2018 07:15 PM
That is obviously not the OEM wiring :)
The switch appears to be a maintained contact motor rated (2hp) thing, controlling the low voltage coil wiring for the starter relay. While that will work, it does remove the power-off safety feature of the starter. If it were me, I’d yank that switch and re-do the wiring with a standard control station switch (NO start/NC stop).
Is there a wiring diagram on the inside of the starter cover? If so, it should show you how it was originally wired. Post a picture or two so the rest of us can see it as well.
CVN72
#6 posted 11-10-2018 02:44 PM
CVN72
#7 posted 11-10-2018 02:50 PM
It looks like the box is to prevent a current overload. Is this necessary?
I want to do away with the overload protection box and replace it with a magnetic paddle switch that fits in a standard sized outlet box.
View shampeon's profile
shampeon
1899 posts in 2424 days
#8 posted 11-10-2018 05:24 PM
Read this, because you don’t seem to grasp how the starter and switches work in these machines.
http://wiki.vintagemachinery.org/Motor%20Starter%20Wiring%20Diagrams.ashx
For large motors, a starter is 100% necessary. Your panel breaker box is to prevent the wires in the walls from starting a fire, not to protect your motor.
You can use a paddle switch with your starter. It will be a low voltage momentary switch that connects to the magnetic starter. You can relocate the starter box to somewhere more out of the way, and add the paddle switch wherever you want.
CVN72
#9 posted 11-11-2018 06:30 PM
OK, thanks for the information.
