Planer / Jointer knives
Forum topic by GrantA posted 11-09-2018 03:22 AM 256 views 0 times favorited 2 replies Add to Favorites Watch
View GrantA's profile
GrantA
946 posts in 1645 days
11-09-2018 03:22 AM
I need to get knives for my 16” double sided planer and my 12” jointer. Suggestions? I can get planer knives from Woodtek (it’s a woodtek machine) for $60 a set (of 3). The machine uses 2 sets. That may be about as good as it gets but I figured I’d ask where you all like to get them.
I also saw that grizzly has some dispoz-a-blade setups on clearance, they’re the posi-set not the easy set (I assume the posi is older /less desirable). Any thoughts on those?
Thanks!
Grant
2 replies so far
View Aj2's profile (online now)
Aj2
1950 posts in 2035 days
#1 posted 11-09-2018 05:04 AM
In my jointer I use M2 and t1 high speed steel. Carbide in the planer
I wouldn’t even consider anything from grizzly esp on sale.
Maybe you don’t have a choice with that woodtek machine.
I think it’s good to know what grade of hss.
-- Aj
GrantA
#2 posted 11-09-2018 11:58 AM
AJ the ones that I’m considering from grizzly are dispoz-a-blade not Grizzly branded, quality knives but it’s the older, potentially more fussy posi-set system not the newer easy-set.
Perhaps I should clarify I’m looking for a good source, thanks for your recommendations on steel type but from where?
