Redoing dust collection
Forum topic by CWWoodworking posted 11-09-2018 03:15 AM 374 views 0 times favorited 3 replies Add to Favorites Watch
View CWWoodworking's profile
CWWoodworking
184 posts in 415 days
11-09-2018 03:15 AM
I am hoping I have a little time over Xmas to re-due my dust collection.
I have added and redone so much the last year that I am currently just hooking a flex hose to what I’m using just to get by.
My dust collection machines are a 2 hp grizzly and a wall mount grizzly.
The wall mount is hooked to chopsaw station and not really looking to do anything different there
I would like to take the 2hp and hook it up to 3 machines-
Vertical panel saw
Table saw
Drum sander
All of these machines are extremely close to each other and looking for ideas on how to make it flow.
This is my somewhat crazy idea. Mount it high on the wall and vent it outside instead of bagging it. Being up high, it would take up less space, and I wouldn’t be tripping over pipe/hose. I could vent it into 90 gallon toters I already have(5).
The vertical and sander connections are on top anyways.
Thoughts?
3 replies so far
5233 posts in 2729 days
#1 posted 11-09-2018 11:36 AM
I’m guessing this is a single stage DC (?) and you want to vent the discharged dust and chips into the totes? I would bet that isn’t going to work very well…the air still has to escape and will carry a lot of the debris with it. If you put a separator into the system (or if it’s already there) then I’d say you’re good to go. You could set it up as planned and see what happens; add a separator after the fact if needed.
View Lazyman's profile
Lazyman
2703 posts in 1623 days
#2 posted 11-09-2018 02:49 PM
I seem to recall that you’ll lose some suction when you add vertical runs in your system but if you are saying that you are removing the filters, that should offset the reduction. If you won’t have a separator at least, you are going to have quite a mess outside your wall, not to mention annoyed neighbors if they are nearby.
Also, don’t forget you will need air coming back into the shop to replace the theoretical 1700 CFM of the 2HP Grizzly you’ll be venting out. In winter months, this could make it impossible to heat your shop effectively if you run the dust separator frequently or for long periods. For example, if you only get 1000 CFM, that will replace the equivalent of all of the air in a 20’x20’x10’ shop every 4 minutes.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3049 days
#3 posted 11-09-2018 04:37 PM
I wouldn’t vent outside unless it’s a cyclone.
Vertical drops are no problem. Just hard pipe it with 6” metal, then reduce to 4-5” for the drop. Keep the curves gradual with large radius where possible. Limit the use of flex hose to a few feet per machine.
Once you use a hard piped system, you’ll never go back to hooking up one machine at a time.
Not sure how fancy you want it, but I’ve had good luck with iVac and Grngate automatic blast gates.
