Oval holes
« back to Woodturning forum
Forum topic by Jack Lewis posted 11-07-2018 06:29 PM 444 views 0 times favorited 3 replies Add to Favorites Watch
View Jack Lewis's profile
Jack Lewis
369 posts in 1316 days
11-07-2018 06:29 PM
A design in my head calls for an 1 inch oval hole centered in the face of a 2 inch segmented piece.
How can that be accomplished?
If I pre-drill the segment at an angle of 15 degrees to simulate a 15 degree ellipse, it is a crap shoot where the finished hole will be after turning away the padding.
I want to place a dark dowel in the hole to simulate a hole that an additional piece will look like it is protruding. I can draft the position of where the hole will start to end up at the center of the finished turning. I have thought of drilling after turning but that does NOT serve the design I intend.
Please keep on topic when replying.
TX in advance
-- "PLUMBER'S BUTT! Get over it, everybody has one"
3 replies so far
View lumbering_on's profile
lumbering_on
578 posts in 727 days
#1 posted 11-07-2018 06:59 PM
I drilled oval holes before by creating a pattern and then using a router to cut out the actual hole using a pattern bit. I made the pattern by drilling out the center and then using a rotary burr and rasp to finish it off.
View BroncoBrian's profile
BroncoBrian
875 posts in 2196 days
#2 posted 11-07-2018 07:21 PM
I would use a pattern and a router as well. Unless you can find one of these on eBay:
-- A severed foot is the ultimate stocking stuffer.
Jack Lewis
#3 posted 11-07-2018 08:32 PM
Is is only a 3/4×1/2” hole, pretty small for a pattern.
I have one of those but it is horizontal instead of vertical!
