Portable Workbench
Forum topic by NewDog posted 08-29-2011 04:59 AM 2399 views 0 times favorited 6 replies Add to Favorites Watch
View NewDog's profile
NewDog
11 posts in 2605 days
08-29-2011 04:59 AM
Topic tags/keywords: question portable workbench
Hi.
I need to get a portable workbench. I would like something that could easily hold a table saw so that I can do my sawing outside. I have looked at the Black & Decker and Skil. Are there any others that you could recommend?
Thanks.
-- Sharla, Virginia Beach
View WayneC's profile
WayneC
13771 posts in 4216 days
#1 posted 08-29-2011 05:05 AM
You might also want to look at a Rockwell Jawhorse…
http://www.amazon.com/Rockwell-RK9000-Jawhorse/dp/B0018MRUN4/ref=sr_1_1?ie=UTF8&qid=1314587084&sr=8-1
View Tim99's profile
Tim99
3 posts in 2543 days
#2 posted 10-21-2011 08:33 PM
Also look at the Benchmark Portable Work Table:
www.BenchmarkTable.com
Heavy duty, portable, plenty of accessories…
View SnowyRiver's profile
SnowyRiver
51457 posts in 3599 days
#3 posted 10-24-2011 03:32 PM
You could design and build one. I think the main thing with a portable workbench is to be sure it’s stable and doesnt move around when you are using it. Maybe build the bench and mount it on a good mobile equipment base that has good locking wheels. Nothing worse than a bench that walks around while you are trying to use it….especially if you are using a table saw or trying to plane something.
-- Wayne - Plymouth MN
View Brandon's profile
Brandon
4152 posts in 3070 days
#4 posted 10-24-2011 03:48 PM
I vote with Wayne—-make your own!
Roy Underhill’s book, The Woodwright’s Apprentice, which I’m sure you can find at the library, has a project for a folding workbench that looks like it’d be pretty stable. It’s especially good for honing in your handtool woodworking skills, but even if you’re only interested in the design aspect of the table, I’d still take a look at it.
-- "hold fast to that which is good"
View PutnamEco's profile
PutnamEco
155 posts in 3405 days
#5 posted 10-24-2011 04:03 PM
I’ve got a portable Bosch table saw on one of those gravity rise stands that often ends up an impromptu jobsite worktable , just put a piece of plywood over it and there you go. I’ve also been known to use a baker scaffold as a work table.
It would help to know if you are just looking for a saw stand and if or for what other uses you have in mind.
Bossmate has a couple of legs that slip over the ends of 2x lumber to make a simple bench.
If you are not averse to spending a little money, there is the Walko workbench system, Festools MFT/3 (multifunction table) , which could be real handy if you have one of their plunge saws, and Kreg has their Klamp Table.
-- “The test of our progress is not whether we add more to the abundance of those who have much; it is whether we provide enough for those who have too little.” ― Franklin D. Roosevelt
NewDog
#6 posted 11-02-2011 07:30 PM
Thanks for all the advice. I built a small addition to my workbench for the time being.
