| Forum topic by xwingace | posted 629 days ago | 5604 views | 0 times favorited | 10 replies | ![]() |
629 days ago |
Got me a brand new chainsaw, but damned if I can get the thing to run. After about 5 attempts and 100 pulls, I got the thing to run for about a minute. -- I'm not as good as I once was, but I'm as good once as I ever was. |
10 replies so far
#1 posted 629 days ago |
Apparently the solution is to talk smack about it, as right after I posted this it started up and ran like a champ. :P -- I'm not as good as I once was, but I'm as good once as I ever was. |
#2 posted 629 days ago |
I have a couple of Husky’s and both like to be fully choked, a few pulls till it fires, then open or take the choke almost off, and then they fire and run on one more pull. Then open the choke and cut. |
#3 posted 628 days ago |
It is possible that you flooded it. -- When the moderator chooses sides, his site sucks. |
#4 posted 628 days ago |
A good kick can go a long way to. |
#5 posted 628 days ago |
What elevation do you live in? I live practically at sea level and every thing I bought with a small two stroke is tuned too rich for sea level and it only gets worse from there as the elevation goes up. Sometimes bumping up the idle speed helps with starting too. There should be something in your manual about carb adjustment. |
#6 posted 628 days ago |
I am at sea level, I’ll try leaning out the mix. -- I'm not as good as I once was, but I'm as good once as I ever was. |
#7 posted 628 days ago |
Ive got a Stihl that only likes to be choked for the first pull, then half choke until it starts. For some reason it floods very easy. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#8 posted 628 days ago |
I have a can of starting fluid and a spark plug wrench near mine (I don’t use it enough anymore to keep the engine starting easy – when I was running it everyday it would start in 1-2 pulls). Just a quick squirt of fluid into the plug hole….put back the plug and boom…starts right off. I have the Husqvarna 41, about 15 years old and it has always been tough to start – runs great…but you almost had to snap your arm off starting the thing. -- Woodworking.....My small slice of heaven! |
#9 posted 628 days ago |
My Husky…. -- Rustfever, Central California |
#10 posted 627 days ago |
Take the saw to a dealer to adjust the carb lol, really it should be adjusted for summer or winter use too. By adjustment i mean 1/8 of a turn each time (not an 1/8 of an inch). |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1525 |
3542 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6150 |
