What finish do you use on your wooden models?
Forum topic by Jason1974 posted 11-05-2018 05:57 PM 425 views 0 times favorited 11 replies Add to Favorites Watch
View Jason1974's profile
Jason1974
140 posts in 557 days
11-05-2018 05:57 PM
Topic tags/keywords: finish wood models question
I can’t decide on what finish or oils I should use on my wooden models.
What do you guys suggest?
-- Jason, Camden, NC -- MEASURE TWICE, CUT ONCE, THEN FORCE IT TO FIT.
11 replies so far
View Dutchy's profile
Dutchy
3193 posts in 2403 days
#1 posted 11-05-2018 08:16 PM
Aerosol spray lacquer
-- https://dutchypatterns.com/
View LittleBlackDuck's profile
LittleBlackDuck
2120 posts in 1055 days
#2 posted 11-05-2018 08:24 PM
- Dutchy
If you do, suggest you spray lightly or those originally moving parts may object!
View crowie's profile
crowie
2809 posts in 2185 days
#3 posted 11-05-2018 08:26 PM
G’Day Jason,
Recently I’ve started making my own Wipe On Poly to the following receipe:
30% Tung Oil
40% Clear Satin Polyurethane
30% Mineral Turps
I’ve even done a trial with a splash of teak stain for a honey colour…
Prior to that I’d used the Pressure Pack Clear Gloss or Satin Lacquer; sometimes Polyurethane..
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
View WoodenDreams's profile
WoodenDreams
374 posts in 145 days
#4 posted 11-05-2018 08:26 PM
You can get Aerosol spray finishes in a variety of stains. For small objects it’s so much quicker vs brush or spray gun.
Jason1974
#5 posted 11-06-2018 12:03 AM
thanks guys, whats your take on danish oil. I see a lot of people using it.
LittleBlackDuck
#6 posted 11-06-2018 02:04 AM
- Jason1974
Danish oil gives a darker hue than tung (depending on brands as well). Danish oil generally (again depending on brands) takes about double the time of tung to cure.
Personally I prefer brush on shellac, dries quickly and if the application area is relatively clean can minimise nibs. Dries quickly (give it a few coats in 30 minutes) and leaves a pleasant gloss after a few coats.
Jason1974
#7 posted 11-06-2018 02:53 AM
Thanks Alex, I’ve been using wipe on poly and wanted to try something different for a change.
View GR8HUNTER's profile
GR8HUNTER
5366 posts in 947 days
#8 posted 11-06-2018 03:57 AM
I like watco Danish oil for like construction vehicles
but for like say a race car I like minwax poly spray gloss :<))
watco does take long time to dry like 3 days or so
View htl's profile
htl
4317 posts in 1394 days
#9 posted 11-06-2018 04:32 AM
Like Tony I use Danish oil and really haven’t tried anything else as it’s so easy and hides any super glue spots I may have missed sanding out.
Be careful with water based finishes as they will raise the grain and add to you sanding work but some people like that?
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View Woodchuckswife's profile
Woodchuckswife
24 posts in 1545 days
#10 posted 11-06-2018 05:46 PM
I dip mine in mineral oil. If it gets broke you can reglue ,sand and redip. never see the fix.
Chuck
WoodenDreams
#11 posted 11-06-2018 06:09 PM
I like the dipping in mineral oil trick.
