Makeing star knobs(and how candles help)
Forum topic by higtron posted 08-26-2011 06:13 PM 2588 views 0 times favorited 7 replies Add to Favorites Watch
View higtron's profile
higtron
235 posts in 2581 days
08-26-2011 06:13 PM
I was makeing some star knobs I choped out for the nuts, and you know when you bed them in the epoxy you’ll get epoxy into the threads. I’m not sure if this is a new idea or not, but it worked like a charm, i wrapped the bottom and the sides of the nut with blue tape. then I fired up a dinner candle, and melted wax into the threaded part of the nut let it cool for a few minute than melted some more into the hole because the first go around shrank away some. set the nuts in the freezer for five minutes. I than took the blue tape off ruffed up the nuts with sand paper and epoxied them in the knobs. when the epoxy dried I took an awl and cleaned out enough epoxy to start a bolt and just threaded it through, the advantage is you can really slop on the epoxy with no worries.
-- A friend will help you move, a good friend will help you move a body
7 replies so far
View lew's profile
lew
11941 posts in 3659 days
#1 posted 08-26-2011 06:17 PM
Cool Idea. Thanks!!
View gfadvm's profile
gfadvm
14940 posts in 2594 days
#2 posted 08-27-2011 05:26 AM
I make all the knobs for my jigs and never glue the nut into the knob. I drill a hole in the TOP of the knob which is smaller than the widest part of the nut, tap the nut in firmly after threading it onto a bolt, and i’m good to go. I haven’t had one come out or get loose yet. My knobs are usually oak or mdf. I use my calipers to measure across the narrow part of the nut [flat to flat] and this is the size drillbit I use. The epoxy thing was just too big a mess and not necessary. Hope this helps someone.
View Arlin Eastman's profile
Arlin Eastman
4095 posts in 2465 days
#3 posted 08-27-2011 09:28 PM
Thanks for the great idea. What did you make the knobs out of.
Arlin
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
higtron
#4 posted 08-28-2011 12:37 AM
Maple it’s what I had in the scrap bin. Thanks
View Brett's profile
Brett
950 posts in 2663 days
#5 posted 08-28-2011 05:15 AM
Why don’t you just buy them? HAha! Just kidding.
You know my method.
-- Hand Crafted by Brett Peterson John 3:16 http://www.TheCrookedNail.blogspot.com
higtron
#6 posted 08-29-2011 03:02 AM
Good one Brett:)
View SalvageCraft's profile
SalvageCraft
274 posts in 2430 days
#7 posted 09-12-2011 11:51 PM
Hmm. This thread looks familiar! I guess I’ll post the same reply I did over at woodtalk ;)
If you have a set of taps, you can just ream the epoxy back out of the nut if you’re sloppy (and why wouldn;t you want to be sloppy?!)
If you don;t have a set of aps, a bolt or some allthread with a notch cut perpendicular to the threads will work. Just clamp the bolt or allthread into a bench vise and go at it with a hacksaw to cut some flutes. Made correctly, these will easily tap just about any wood as well.
-- Jesse --
