math problem
Forum topic by Partridge posted 185 days ago 471 views 0 times favorited 25 replies Add to Favorites
View Partridge's profile
Partridge
158 posts in 443 days
185 days ago
I know we live in a world of Google Sketh and this is easy to finger out but i do not have a computer in shop so.
I am putting a box together and the ends are tilted 10 deg. and flush with edges. So if the sides are 3/4×2. what would be the the ends 3/4 x ??
_ \ \
-- Do it right the first time. Becuase fixing it is a wast of time.
View GaryK's profile
GaryK
8489 posts in 475 days
185 days ago
Do you mean that the box narrows from top to bottom at 10 degrees?
Not sure what you are asking. Do you have a drawing?
Partridge
185 days ago
no it is a SQ box. just the end tilt
View motthunter's profile
motthunter
1224 posts in 286 days
185 days ago
from your writing, I am not sure what you mean. Can you do a hand drawing and post it?
-- making sawdust....
Partridge
185 days ago
math
i what to now the height of ? before 10deg angle
View leonmcd's profile
leonmcd
177 posts in 458 days
185 days ago
My guess would be 2.114521888” and the 3/4” face will be slightly larger than 3/4 at 0.769840042”
Is this what you had in mind?
Might want to try this on some MDF just to be sure.
-- Leon -- Houston, TX - " I create all my own designs and it looks like it "
View fredf's profile
fredf
188 posts in 197 days
185 days ago
I am a bit rusty with my trig but I make it out to be 2.163 or not quite 2-21/128
try doing an actual sized drawing and measuring . . .
fred
-- Fred, Springfield, Ma
View swied's profile
swied
43 posts in 248 days
184 days ago
I think we are all struggling to understand your diagram. Here is my guess.
sin(x) = opposite / hypotenuse
In this case x = 80 degrees, the opposite side is 0.75”, and you are seeking the hypotenuse.
You can use Google as your calculator…
http://www.google.com/search?q=0.75%2Fsin%2880+degrees%29&btnG=Search
My answer is 0.761569959”
-- Scott, San Diego
Partridge
184 days ago
thank you swied,
that got the length of the long angel but i am looking for the length of the 90deg.
all so the wright way of fingering it out.
GaryK
184 days ago
I can’t figure out your drawing either. If you could draw it like a blueprint filling in the numbers you
know I could fill in the blanks.
Partridge
184 days ago
how about this if you had a triangle that was 10-90-90 and one of the 90deg lengths was 3/4 what would be the other. you are looking strait on at a board 3/4 thick standing up at 90deg. then you cut the bottom 10deg.
i want to no how much do i have to measure up to get that 10deg angle
GaryK
184 days ago
The hypotenuse (the length of the angled side) for a 90 degree right angle triangle with an angle of 10
degrees and one side 3/4” is 4.3191”.
The length of the 3 sides would be 3/4” x 4.2535×4.3191
Partridge
184 days ago
garyk
i do not know how to say this.
View Peter O's profile
Peter O
633 posts in 361 days
184 days ago
Okay, you have a box where the vertical sides are 2” high, but one side is tilted 10 degrees. You want to know how tall your angled workpiece should be so that when you cut 10 degrees off of the top and bottom, you are left with a 2” high piece. Correct so far?
AutoCAD says your blank should be 2&5/32” ...
End view 10 degree cuts off top and bottom
The solid black lines are an endview of your workpiece, the dashed red lines are your cut lines.
If you have trig tables or a calculator that does trig, you can do it that way, but I’m just not up to it today!
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
Partridge
184 days ago
thank you for the pic. peter
iam trying to do it the long way
5692 posts in 338 days
184 days ago
Partridge, the answer is 70.9276mm or 2 51/64”by trig calc.
184 days ago
The simple way to do this is to break it into triangles (see shaded areas) and use the sine rule to calculate the missing sides. Add together the lengths of A & B on my sketch & you have the answer. I know that is simplified but if you remember your trigonometry from school it’s a snack. A=49/64ths (19.3439mm) B=2 1/32” (51.5837mm), total of 2 51/64” (70.9276mm)
Glad to help anytime.
View unknownwoodworker's profile
unknownwoodworker
89 posts in 190 days
184 days ago
I’m soooo confused !!!!
-- ??? My mistakes heat the house. It's very warm in here. ???
Peter O
184 days ago
Grumpy – if the material is 3/4” thick and you tip it 10 degrees, I don’t think you’re going to add nearly an inch in width. You’d have to rotate it more like 28.8 degrees. In your sketch, it looks like you have the piece rotated maybe 20 or 30 degrees (?).
So, now for the math, based on Grumpy’s sketch …
A = tan(10) x .75
A = .1763 x .75
A = .132225
B = 2 / sin(80)
B = 2 / .9848
B = 2.030869
A + B = .132225 + 2.030869 = 2.163094
21/128 = .1640625, which is pretty darn close, but most tapes only read to 32nds.
5/32 = .15625 which is less than .007 off – close enough to sand.
So I’m sticking with 2 5/32”.
183 days ago
Sorry Pete. I agree with you 2 5/32”. I put the wrong angle in the calculations.
Peter O
183 days ago
Yay! Grumpy and I got the same answer, so it must be right!
View gator9t9's profile
gator9t9
282 posts in 191 days
183 days ago
Good job to the LJ mathematicians!!!!!!! Oh yes ….Next I suppose youse guys will be splaining the philosphy of the 3-4-5 rule …
-- Mike in Bonney Lake " If you are real real real good your whole life, You 'll be buried in a curly maple coffin when you die."
Peter O
183 days ago
Philosophy now, huh?
ahem …
Based on the posits and theories of the ancient Greek philosopher and mathematician Pythagoras, the 3-4-5 rule is not so much a “rule” per se, as it is a deep and personal understanding of the true nature of the balance and rhythm of the world around us …
183 days ago
Don’t Knock the 3-4-5 rule Jocks. We would be lost without it. LOL.
How about this one.
To find the area of an irregular triangle when you know the lengh of the 3 sides but not the angles.
Area = square root of [s(s-a)(s-b)(s-c)] where s=1/2 the perimeter & a,b&c are the lengths of the 3 sides.
Ok Jocks, lets see what else you have stored in the memory cells.
View Sir_Robert's profile
Sir_Robert
34 posts in 238 days
182 days ago
Do you guys realize that while you’re Pythagorizing your time away, there’s wood in your shop waiting to become something?
-- Sir Robert
Partridge
181 days ago
thanks gain LJ…....
Bookmark And Share This Page
