advice about roundover plane
Forum topic by moshel posted 08-26-2011 05:47 AM 3879 views 0 times favorited 5 replies Add to Favorites Watch
View moshel's profile
moshel
865 posts in 3588 days
08-26-2011 05:47 AM
Topic tags/keywords: plane
As I got stung my the “make your own plane” bug and made my first (project coming soon), i thought to make a small roundover plane (1/8”) to round over my cutting boards. problem is, most planes like this are designed for face grain and not end grain, so I was wonder if any of the DIY plane makers or the professionals can give some advice about the angle of the bed and the plane iron edge. would a scraper plane work better than low angle one? any other considerations?
Thanks,
Moshe
-- The woods are lovely, dark and deep, but I have promises to keep...
5 replies so far
View David Kirtley's profile
David Kirtley
1286 posts in 2903 days
#1 posted 08-26-2011 06:42 AM
It is going to depend on the wood. A 45 degree angle is always a good starting point. You get into all the bevel up and down arguments and it all comes out about the same.
Before you get too involved, make a scratch stock and see how it feels at different angles.
Here is one from Peter Follansbee:
moshel
#2 posted 08-26-2011 06:49 AM
Thanks David, but I am quite sure this is true for long grain, not end grain. my experience with regular planes on end grain shows that either very low or very high angle should work.
View daltxguy's profile
daltxguy
1373 posts in 3819 days
#3 posted 08-27-2011 01:28 AM
umm, wait for your package to arrive? You may find something in there :)
but also, a spokeshave works nicely
-- If you can't joint it, bead it!
David Kirtley
#4 posted 08-27-2011 05:45 AM
Yes, the scratch stock is high angle. You can see how high will give you a good finish.
moshel
#5 posted 08-27-2011 12:50 PM
after reading a little about this, it seems that you are right and this is the way I should go. Alas, it seems that a thinner, sorter material than my planer blades is called for. I think I have some old saw blades that can be converted…
