Framing Nailing?
Forum topic by Beginningwoodworker posted 08-26-2011 03:50 AM 1026 views 0 times favorited 12 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3909 days
08-26-2011 03:50 AM
I am wondering would a Paslode F350 Framing Nailer work on my Bostitch Trim Air Compressor? Someone told me my compressor wont work with a framing nailer because its to small. I think its 1.5 gal.
12 replies so far
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3345 days
#1 posted 08-26-2011 04:31 AM
The worst that happens, you pause between runs of nails. I used something similar when nailing up the walls on an addition I did. The thing kicked on a lot.
-- Random Orbital Nailer
View jusfine's profile
jusfine
2422 posts in 3161 days
#2 posted 08-26-2011 04:38 AM
I have an old Thomas compressor (1.5 hp) that powered a framing nailer with ease, it should work!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Beginningwoodworker
#3 posted 08-26-2011 04:42 AM
Yes I am afraid it will kick on alot.
View Bob Kollman's profile
Bob Kollman
1798 posts in 3426 days
#4 posted 08-26-2011 07:37 AM
Buy the nailer, test it on your compressor, if your happy keep it, if not take in back to
the store. That method works for me every time.
-- Bob Kenosha Wi.
View cloakie1's profile
cloakie1
204 posts in 2790 days
#5 posted 08-26-2011 11:33 AM
it should work….you just might not be able to bang them as often as you can with a bigger compressor
-- just get stuck in and have a go!!!
View Cato's profile
Cato
701 posts in 3548 days
#6 posted 08-26-2011 12:58 PM
I have the same nailer and it should probably work with your compressor as long as you don’t try any rapid nailing.
If you do you will see stair stepping on the nails as the air drops off.
Smaller nails maybe not so much but definitely on the 3.5 inch nails.
When I framed my shed I ended up getting a 4.5 gal and that solved it. Try it and see though since you already have the compressor.
View nailbanger2's profile
nailbanger2
1041 posts in 3379 days
#7 posted 08-26-2011 01:02 PM
As others have said, the comp. will be running a lot. One thing not said is, if you try to rush it, the gun will jam on you.
-- Wish I were Norm's Nephew
Beginningwoodworker
#8 posted 08-26-2011 04:07 PM
Take make cordless nailers as well which they is most famous for.
View David Craig's profile
David Craig
2137 posts in 3344 days
#9 posted 08-28-2011 02:51 PM
The smaller compressor should only affect pace. Impatience would be rewarded with proud nails but I have seen construction workers frame with that size of compressor many times. I have also seen that size used with a palm nailer, which can be demanding as well. Just the sacrifice that is made when you want to deal with less weight.
David
Beginningwoodworker
#10 posted 08-28-2011 09:12 PM
Ok, David. Would I be damageing my compressor?
13641 posts in 3577 days
#11 posted 08-28-2011 09:31 PM
just slow down with the nailing
let the compressor catch up
and have a break from time to time
so it doesn’t overheat
keep it in the shade
drink some lemonade from time to time
Beginningwoodworker
#12 posted 08-28-2011 09:41 PM
