Douglas Fir beams
Forum topic by Belg1960 posted 638 days ago 801 views 0 times favorited 11 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
507 posts in 1237 days
638 days ago
Topic tags/keywords: question
Hey guys, I have the opportunity to get some wood from a post and beam ceiling from a building build in 1930’s these things are massive but the tightest growth rings on lumber I have ever seen. They measure about 3”x14” I really want to take some but just dont have large equipment to machine it into manageable boards. Do you guys have any ideas what I could make with lumber this size? Thanks Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
11 replies so far
View chrisstef's profile (online now)
chrisstef
5304 posts in 1178 days
#1 posted 638 days ago
If they are good any dry you can do most of the work on a table saw. Cut both sides leaving about 1/8 to 1/4 left in the middle. Pry it apart with a screwdriver handplane the nub and youre good to go. Take em! Youll figure somethin out.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View Jonathan's profile
Jonathan
2568 posts in 1222 days
#2 posted 638 days ago
I snagged some old beams a while back and am still waiting for the muse to make an appearance. These beams are from around 1890, so I figure there is no rush to figure it out. I’d certainly take my time with these treasures, rather than rushing into it and regretting my decision, since they’re not easily replaced at the lumber yard.
If they’re 3”-thick, I’d think about leaving them in there current form and ganging them together for a rustic tabletop maybe? 14”-wide would also be a good entry table top, or a sofa table top. Maybe do a mixed piece where you’ve got the rustic top with a clean, modern base underneath of some contrasting wood, such as walnut or mahogany?
I’ll be curious to see where your muse leads you on this one. It sounds like you’ll have numerous projects from these beams since you’ll have multiples, which will be nice.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View plantek's profile
plantek
276 posts in 971 days
#3 posted 637 days ago
I would consider the table option.
-- If you want it and it's within reason... It's on it's way!
View Moron's profile
Moron
4439 posts in 2065 days
#4 posted 637 days ago
like some one said, cut half way through, flip the board over and cut through the other half………you should be good to go
View helluvawreck's profile
helluvawreck
10495 posts in 1039 days
#5 posted 637 days ago
We have a friend here in our town that is making furniture out of the old beams and flooring that came out of the old Goodyear plant that was torn down here. The plant had been here since the early 1900’s and he just uses regular shop equipment – table saws, band saws, etc.. I have not seen any of his furniture.
View Nomad62's profile
Nomad62
568 posts in 1130 days
#6 posted 637 days ago
As nice as it sounds I would recommend leaving it be until you have a specific use for it. You can always cut it to pieces later. You may even end up using or selling for use as beams to build another shop; new beams are spendy. Maybe spray them with a bug spray and/ or water repellant? Nice grab!
Belg1960
#7 posted 635 days ago
Guys, thanks so much for the replies. Well it seems like I have come out the other side of the Hurricane with very little damage just one gutter to fix.
I like the idea of a table but but don’t understand the reasoning behind cutting from the top and bottom, my 10” table saw will cut thru all the way. I would do it in two passes and get a cleaner cut, NO?? I would really like to make my son a coffee table but have something more funky and hip than a plain rectangular top with a rigid square leg base. Any pics with some ideas would be much appreciated.
As far as storing some of this wood could you tell me the best way to store it so it does not warp. It is nice and dry, but to I still sticker stack them? Also do I dress them and then store Or leave them in the original condition to store? Thanks Pat
PS any other ideas on things to make with them would be appreciated.
Jonathan
#8 posted 635 days ago
Try going to Google Images and typing in such phrases as:
-beam coffee table
-wood beam coffee table
-modern coffee table
-modern beam coffee table
-modern beam table
-wood beam furniture
-beam furniture
-beam table
-rustic beam table
-etc.
That’s what I did after we snagged the beams I mentioned above. I’ve gotten a couple of ideas from doing that specifically for this wood, and countless other ideas as well for other pieces that I haven’t made, but have a rough design in my head and on scratch paper.
I am personally a big fan of Google Images. You have to do a bit of sifting/filtering, but it’s worth it, in my opinion.
View miles125's profile
miles125
2177 posts in 2177 days
#9 posted 635 days ago
Make you a 2 1/4” thick custom front door out of them. Not too hard to find hardware for that thickness.
-- "The way to make a small fortune in woodworking- start with a large one"
View Scsmith42's profile
Scsmith42
125 posts in 849 days
#10 posted 635 days ago
To me, the real value in those beams is the width; old growth wide planks are difficult to find!
For not a lot of money, you can find someone local with a woodmizer or other band type sawmill and resaw them into an appropriate thickness for your projects. For a table top, you could have them sliced in half, yielding two planks that are 6/4×14”, netting a 5/4 table top from them.
Woodmizer maintains a list of their sawmill owners that you can check to see if anybody is local. You can also check on either Woodweb or The Forestry Forum.
For other projects, you could have them resawn into three 4/4 thick boards, 14” wide, and use them on future furniture projects.
By all means grab as many of them as you can, and store them indoors.
-- Scott, North Carolina, www.quartersawnoak.com
Belg1960
#11 posted 628 days ago
I was wondering has anyone ever used one of these http://www.machinemart.co.uk/images/library/product/large/06/060337764.jpg?2 I thinking to try and carve a simulated live edge on my beams, Ive been doing some googling for inspiration and have come up with several ideas that I want to bring together once I talk to my son and see exactly what he wants for storage or open base. I’m going to make him a man’s coffee table for his dorm room.
