Smallest stable of bench planes?
« back to Hand Tools forum
Forum topic by Brett posted 639 days ago 788 views 0 times favorited 26 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 855 days
639 days ago
If money were not an issue, I’m sure it would be fun to have a stable of 30 or 40 Lie-Nielsen, Veritas, and Stanley Bailey Bed Rock or sweetheart bench planes in sizes 1 to 8, with soles both smooth and corrugated, and each with several irons of varying combinations of bevel angles and camber. However….
Money being the issue that it always is for us mortals, what is a minimum, basic set of bench planes that is required to handle most woodworking tasks? I know some old masters claimed to use a #7 for everything, but that seems too limited. Can I get by with just a #4 or #4 1/2 smoother, a #5 jack plane, and a #7 jointer? (Remember, we’re talking bench planes, not block planes, rabbet planes, etc.)
If I also have a #3, #5 1/2, #6, or #8, what could I do with them that I couldn’t do with the first three sizes I mentioned? What about irons? Is it beneficial to have two #7s, for example, one with a straight iron and another with a slightly cambered iron? What about having a #5 with a slightly cambered iron and another #5 with a deeply cambered iron? What about using two #4s, one with a normal iron and another with a back bevel of 10 or 15 degrees for highly figured wood?
What are your thoughts on a good, basic set of bench planes that include sizes and irons that would serve me well for most of my woodworking, and not include planes that I would almost never use?
-- More tools, fewer machines.
26 replies so far
View dbray45's profile
dbray45
2018 posts in 949 days
#1 posted 639 days ago
There are a number of schools of thought – and you will hear many here.
I would start out with a low angle block plane, a smoother and jointing plane to start. Get the cheapest you can buy, take them home, clean them up and sharpen them. Once you figure out the in and outs, you may drop them a couple of times, mess upt the blades (these cheap ones have soft blades) and learn how to sharpen them, you will identify and know what you will need to do the work you want. If you break one, minimum expense, if you break a $300 or $500 LN plane or run it acroos a steel screw head – well, I have seen grown men cry from doing this. Removing a chip from a soft blade takes 10-15 minutes, fixing a chip in a good hardened blade can take a couple of hours.
This may sound strong but it keeps you from spending a whole lot of money on stuff you may not need. After you grow out of the cheap stuff, buy the best tools you can afford and enjoy them for a long time.
Besides, if you are working on reclaimed or junk lumber – grap the cheap tools until you know what you have.
-- David in Damascus, MD
Smitty_Cabinetshop
6413 posts in 790 days
#2 posted 639 days ago
For a basic set, yes to a quality low angle block plane. This one should also have an adjustable mouth. Think Stanley #60 1/2 or Veritas, LN equivalent. Can’t go wrong there, will always use it.
Next would be a workhorse jack plane. Again, with the Stanley numbering scheme that’s a #5. Smooth or corrugated, whatever you find. You’ll camber this iron to the heavy side; it’s for hogging out material on edges and when facing stock across the grain and diagonally.
Then a jointer, Stanley #6 or #7 or #8. If you’re not into larger scale furniture, I’d recommend a #6. But it’s your call, because a #7 will do fine, too. It’s for making flat, both faces and edges.
Finally, a good smoother. And here’s where it could get interesting with multiple blades, changeable frogs, potentially redundant sizes, etc. So start with a basic smoother, Stanley #4 if it’s pre-war, otherwise an early bedrock or Veritas / LN. As is, and depending on the wood you work with, it will handle 90% of the tasks you throw at it. For small areas of tear out, if you don’t have a scraper plane (Stanley #80; it handles small as well as stubborn), you’ll benefit by having a smaller footprint smoother. Think #3 or even a #2. That these planes are able to reach into and address small spots is golden. Keeps you from having to work larger areas just to get a silver dollar sized spot.
And that’s the core. And my opinion. :-) So take it with a grain of salt.
From these, adding a wider smoother (a #4 1/2) helps tackle panel-sized smoothing tasks.
I step through using key bench planes here.
Regarding multiple irons, I’m sure there are craftsmen that do it, but it seems to be a hassle. In golf, it’d be like having three wedges in your bag. Unless you know you need each of them, learn to use one well. That means a light camber on the smoothers, little or none on the jointer (I have some), heavy camber on the jack, and a straight blade on the block.
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
View Don W's profile
Don W
9973 posts in 740 days
#3 posted 639 days ago
Here is what I’d suggest, and its pretty much in line with the others. A 4 or 4 1/2 for smoothing(start with a 4 just because they are cheaper), a 7 or 8 (although I think a 6 would suffice as well) for a jointer. A jack (a #5) would be next, but I typically use a planer, so it would be last on my list. As for multiple irons, You can usually buy Stanley #4’s for $10-$15 at flee markets and such. I’d buy the whole plane instead, but agree its nice if you want to have a variety of angles on your irons, either way you go.
What can you do with the others? Well…..boost about how many you have. Sometimes you’ll reach for a different size depending on the job, but the 3 core suggested will do everything you need. Its a “do you need it” or “do you want it”. I buy them because enjoyoy restoring them, and i count it as an investment. I have very few planes I couldn’t sell for twice what I paid, or more.
View 000's profile
000
3352 posts in 789 days
#4 posted 639 days ago
Get yourself a copy of David Fink’s book “Making & Mastering Wood Planes” and you will never need to buy another hand plane again.
You might want one from Veritas, but you’ll never need one.
-- When the moderator chooses sides, his site sucks.
View WayneC's profile
WayneC
9596 posts in 2269 days
#5 posted 639 days ago
I would agree with Don. For bench planes, you need to perform 3 operations Rough Stock Removal (#5 or #6), Flatten (joint) the surface of the board (#7 or #8) and smooth the board (#3, #4, #4 1/2, #5 1/2).
Choice is a personal preference factoring in how strong you are, what size hands you have, and what feels right to you. For example, some people prefer heavy planes. So they would go with a 5 1/2 for smoothing. Get your hands on different sizes and see how they feel to you.
There are options and trade-offs related to this as well. For example a low-angle jack plane can perform many of these operations by swapping out blades. Also, Some people use wooden jack planes or tranisitional planes for rough stock removal instead of bailey style metal planes.
From a block plane perspective, (as you said, not a bench plane) I would recommend a low angle adjustable mouth plane such as a #60 1/2 or a #65.
Brett
#6 posted 639 days ago
Thanks. I guess I should have pointed out that I already have a two #4s, a #4 1/2, a #5, a #7, and a #8, plus a old #60 1/2 block plane and a modern Stanley standard block plane. I obviously have some duplicates, and I’m wondering whether I should add some missing sizes and have a collection, or sell the duplicates and spend the money on something else (like a back saw, a shoulder plane, or a router plane).
WayneC
#7 posted 638 days ago
I would stop adding more bench planes and then buy tools based on what your building. I would reccomend your next purchase be a book. For example, The new traditional woodworker the anarchist's toolchest.
View Dan's profile
Dan
3480 posts in 1052 days
#8 posted 638 days ago
Brett, it all depends on what type of work you are doing. You have more then enough bench planes do do all the task that a bench plane can do. If you got a #3 or #6 I don’t think they can do anything your others can do. So its all ones personal preference.
As for saws, shoulder planes and other specialty planes it will all depend on what work you do and again your personal preference.
However in my opinion if you are looking to get more planes a shoulder plane may be a good choice for your next one.
-- Dan - "Collector of Hand Planes"
Brett
#9 posted 638 days ago
Thanks. I have the “New Traditional” book, but not the “Anarchist’s” book. I’m having fun fixing up the old planes, but I’m torn between having a cool-looking row of #3 through #8 Bailey planes (#1 and #2 are out of the question) and waiting till I can buy the other tools, or selling the extra planes and spending the profits to buy the other tools right now.
Don W
#10 posted 638 days ago
I strongly disagree with Wayne. I would keep adding planes and buy tools based on what your building and ALSO buy the books. But then I have a bit of a “PLANE” issue. Someone mentioned selling duplicates. Is that really an option? :-)
Really, what Wayne says make perfect sense. But then, I can NEVER walk by a plane for sale.
dbray45
#11 posted 638 days ago
If you have duplicate planes, change and set the angles differently on the duplicates. That way you have what you need without re-configuring the hardware.
WayneC
#12 posted 638 days ago
Lol…... Use your tools lest you be accused of being a woodworking poser or even worse a collector.
dbray45
#13 posted 638 days ago
Wayne – thats not fair, you weren’t supposed to tell him until it was too late.
Don W
#14 posted 638 days ago
not a collector!!! oh the shame.
View Brit's profile
Brit
4204 posts in 1015 days
#15 posted 638 days ago
Don – You’ve got to watch that Wayne you know. Its because of him that I’m restoring another brace. :-)
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
