New Box Experiment
Forum topic by Jimboe posted 08-25-2011 02:57 AM 1632 views 1 time favorited 26 replies Add to Favorites Watch
View Jimboe's profile
Jimboe
257 posts in 3624 days
08-25-2011 02:57 AM
Topic tags/keywords: question trick tip
Ok …so now i work for a waterbed store and we get a lot of free 2 X 10 pine boards from old waterbed frames(some people get into the new softside style). Pine wood isn’t the most beautiful board in the world so i like to make it look a little more exotic than it really is . I decided i would and a dark stripe down the middle of the board but wanted to look like it it was the actual wood that made this darker color . First off i had to split the board in half . My band saw only opens up to about 6 inches so i have to cut the board in half to fit in my band saw to resaw..i really wanted it to look seamless so i decided i would follow the grain to cut the board in half( i didnt get it perfect LOL but it came out ok ).
Wish i would have taken more pictures of the glue up on the boards and the box . Let me just say the glue up on the box was way to much fun (thought i was gonna lose it LOL) I made it so that the top lap jointed the sides and ends …and the ends lap jointed the sides ….ughhhh. needless to say it was a humbling experience .After the glue dried i routed the corners with a round over bit . Looked pretty good . I proceeded to my sanding . I tried something new.. usually i just sand it down to 220 then start my finishing. This time i sanded to 220 then wet the wood to raise the grain and sanded again 220 and wet again . I then sanded it with 400 grit and wet again then 600 wet and sand . it really did look nice and smooth !!! Next was to tape off where i was going to add the walnut stain stripe down the middle and sides. I tested some clear tape the other day and got a good result so thats what i used . The clear tape so that i could see the grain and use a razor to cut on the grain line .
After cutting out the tape i stained the middle with dark walnut stain . I looks pretty good but i dont know should i stain the natural pine a crazy color like yellow lite blue ? or should i leave it the way it is ???
comments welcome…thanks for looking
26 replies so far
View HerbC's profile
HerbC
1709 posts in 2734 days
#1 posted 08-25-2011 03:05 AM
I like it like it is…
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View BobTheFish's profile
BobTheFish
361 posts in 2426 days
#2 posted 08-25-2011 03:08 AM
leave it.
View gfadvm's profile
gfadvm
14940 posts in 2564 days
#3 posted 08-25-2011 03:19 AM
A really cool idea! Leave it like it is.
View sedcokid's profile
sedcokid
2729 posts in 3473 days
#4 posted 08-25-2011 04:24 AM
I agree leave it….
-- Chuck Emery, Michigan,
View ksSlim's profile
ksSlim
1264 posts in 2764 days
#5 posted 08-25-2011 04:41 AM
Nice use of found material. I like the stain like it is. Top coat and create another ad infinitum.
-- Sawdust and shavings are therapeutic
View tom427cid's profile
tom427cid
294 posts in 2345 days
#6 posted 08-25-2011 07:10 AM
Looks great-leave it.
tom
-- "certified sawdust maker"
View rance's profile
rance
4255 posts in 3035 days
#7 posted 08-25-2011 07:20 AM
Leave it. And give us some bigger pictures. That is fantastic.
So you’re saying you ripped it down, resawed both pieces, then glued it back together where you ripped it? I have a friend that does crazy stuff like that. Whatever it takes to get it done. :)
View pariswoodworking's profile
pariswoodworking
386 posts in 2359 days
#8 posted 08-25-2011 02:08 PM
It looks great. Leave it.
-- Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. -- Albert Einstein
View Gene Howe's profile
Gene Howe
9939 posts in 3303 days
#9 posted 08-25-2011 03:02 PM
Leave it!
Ingenious solution.
16272 posts in 4093 days
#10 posted 08-25-2011 03:34 PM
Leave it.
Great idea!
View Charles Maxwell's profile
Charles Maxwell
1096 posts in 3681 days
#11 posted 08-25-2011 04:05 PM
”...Pine wood isn’t the most beautiful board in the world so i like to make it look a little more exotic than it really is…” Oh I don’t know . . . I rather think pine has some beautiful lines when finished properly! The problem with pine is not necessarily its ‘lack of beauty.’ The problem with pine is its physical characteristics – splinters, soft, moves a lot, weakness, sappy… etc. But, the wood itself has a rear beauty to it and your box shows that perfectly. Well done!
-- Max the "night janitor" at www.hardwoodclocks.com
View Richard's profile
Richard
1916 posts in 2565 days
#12 posted 08-25-2011 09:22 PM
I really don’t see what the problem is here. Don’t mess with it, it looks fine.
Jimboe
#13 posted 08-25-2011 10:08 PM
Thanks everyone …guess ill leave it be =)
Charles.. your right ive seen some really nice pine also …its just people like the exotic stuff and it sells better =)
Rance…i used my smart phone to take the pictures ..its a pretty big file ??? dont know why its so small .
Ksslim… say what LOL
OK so this morning i went to the shop and started work on the hinge. I wanted to make a really crazy looking hinge for the box . Id been thinking of making a hinge with crazy looking fingers or claws on the top ..so this is what i came up with . First i cut the slots for the hinge on a 2×6 piece of pine . I pulled out my trusted finger joint jig and got started
After cutting the finger joints i split the 2 X into 1/2 layers and taped the edges together so that i can match both top hinges.
after taping them i proceeded to cut the top design . Ok i had no clue what was gonna turn up so i let the bandsaw do the work and i just moved it where ever it wanted to go LOL i came out with this …
as you can see he bottom hinge came out nothng like i had drawn …i like better what actually came out .
i set the hinge up to be sculped and went at it
so this is what is gonna look like what do you think is it too much ??? another question how would be the best way to attach it. I want to finish the box then attach the hinge but if there is a better way im all ears
Thanks again yall
View 489tad's profile
489tad
3292 posts in 2886 days
#14 posted 08-26-2011 12:12 AM
screw the hinges on from the inside. They look cool.
-- Dan, Naperville IL, I.G.N.
View Tim Kindrick's profile
Tim Kindrick
369 posts in 2428 days
#15 posted 08-26-2011 01:52 AM
I love the dark stain idea!!!! Very creative!!! As for the hinge, maybe use some brass pins glued in with epoxy?
-- I have metal in my neck but wood in my blood!!
