" Dull Planer Blades " (Sharpened)
Forum topic by dlcarver posted 595 days ago 1498 views 0 times favorited 9 replies Add to Favorites Watch
View dlcarver's profile
dlcarver
260 posts in 626 days
595 days ago
Topic tags/keywords: planer sharpening joining
Does any one out there know of any way to sharpen your own Planer blades yourself ? I feel sure there is a way to do it. What do you do when you accidentally hit a nail and get nicked ? I am sure that people do not just throw away dull or nicked ones only to buy new ones.
I also would like to know how you keep the board going through without hesitation, and sometimes come to a complete stop ? ......... having to be pushed on through ‘till you have no choice but to take another thinner board and push on through. I feel this is very dangerous. I have had 2 planers now. They both are guilty of this. The first one was a Parks with steel fluted roller on top and rubber on the bottom. It would not pull the board through in the rough at all…..... then only half of the time when I was able to get one pass from it. My Grizzly I now have , is not as bad, but still does the hesitation thing.
THANKS ALL!
DAVE
-- Dave Leitem,Butler,Pa.,http://dlcarver.etsy.com
View GaryK's profile
GaryK
9533 posts in 885 days
595 days ago
It’s very hard to sharpen planer blades due to their length. The blades on my Delta are throw away. they do have two edges though so you get twice the life out of them.
I sharpen my jointer blades, since they are much shorter, on my Tormek.
When I ever get a new planer I will get a cutter head with indexable inserts.
Dick, & Barb Cain
7041 posts in 1196 days
595 days ago
Try taking a smaller bite on your first passes, that may stop the slippage.
View tenontim's profile
tenontim
1319 posts in 641 days
595 days ago
If your infeed rollers are correctly set, you’re not going to get the wood to go through with dull blades.
This is what I use for sharpening planer blades. It will sharpen up to 20” long blades. http://www.grizzly.com/products/G2790/images/
-- Tim -- http://tmuli.com
View Blake's profile
Blake
2760 posts in 771 days
595 days ago
As far as slipping, make sure the rollers are clean too. Wipe them down with some mineral spirits if they are coated with wood chips.
Without specific equipment, there is no good way to sharpen the knives yourself. Several models of newer planers use disposable blades which are also double sided. These are a lot easier to deal with and more economical at the same time.
View SteveKorz's profile
SteveKorz
2030 posts in 610 days
595 days ago
FWW's book on Proven Shop Tips has a few methods of doing it with a sled and a cupstone on a drill press. The jig is actually on the cover of the book. The jig looks like it would be really inexpensive to build, but I have not tried it yet. I haven’t had the time. I’ve heard so many horror stories about how each blade has to be the EXACT same weight or the machine will make terrible cuts, (or has a high speed come-apart), etc, etc… almost makes me afraid to try it. (I don’t know if any of that is true or not)
This sled would allow you to regrind it enough to take the chips out if you did try it. I would bring the jig and table up to the cupstone, and not use the drill press handles to bring the cupstone to the blade… or it will be terribly inconsistent. If you didn’t have a drill press, you may be able to rotate the jig 90 degrees and try it on a bench grinder. I wouldn’t get the blades hot or the first pass with some medium density wood and you would smoke those blades. If you find a way that works for you, let us all know.
(I bet Daren Nelson would have the answer to this, he does this kind of thing for a living)
View HokieMojo's profile
HokieMojo
1142 posts in 624 days
595 days ago
i didn’t have a problem with this at first, but I’ve been planing a ton of the walnut I bought and some of it is really rough. when it is feeding through, i keep my hand on the crank. As soon as it gets stuck, I loosen the crank and it starts moving again. I couldn’t tell if yours wasn’t feeding because it was too loose or too tight though.
View 8iowa's profile
8iowa
592 posts in 657 days
595 days ago
Dave:
I just finished planing about 100 board feet of hard maple on my Shopsmith Pro Planer with knives that I sharpened myself. I could not ask for better results. For sharpening, I use a conical disk sander with 150 grit aluminum oxide paper. The blades fit in a special jig, a small sled actually, that I lock the blade in, and then pass it along the fence with the blades just touching the sanding disk. I then finish hone by hand on my water stones. The blades can shave hair on the back of my hand. If I had to, I could hand sharpen the blade on a flat glass plate starting with 220 grit wet/dry paper. I took a tip from Nick Engler, if you get a nick in your blades, you don’t have to grind it all out. Simply position one of the blades about 1/32” offset from the others and the ridge in the wood will disappear.
In the past, before I had a dust collector, my rubber outfeed roller would get slippery and I had to clean it often with mineral spirits. The dust collector eliminated any feed problems.
View fredf's profile
fredf
320 posts in 606 days
595 days ago
might try some paste wax (Johnsons, Butchers etc NOT automotive as it contains silicone, and will raise heck with finishing the wood) on the bed
-- Fred, Springfield, Ma
3710 posts in 876 days
595 days ago
Hi David;
You probably have the answer to a bunch of small problems, which when combined are leading to the results you’re getting.
I hone the blades while they’re still mounted on the machine, but for a good sharpening, I send them out.
I keep thinking of changing the cutter head on my powermatic with one with indexable inserts. But the $ 1.200.00 keeps stopping me.
